Old 11-10-2014, 10:23 AM   #1
Latitude 0's Avatar
Air Mattress
The 64,000 dollar question, does anyone make a air mattress that will hold air for longer than 8 hours. I have a really nice couch in my RV with an air mattress that came with it, I feel so embarrassed when I have guest over and by morning the dang this is deflated.The controls are set to position that it is suppose to be at to hold air and the bottom valve is secure but still deflates a large amount over the coarse of the night or is this nature of the beast for an air mattress and if so what would be a alternative means for bedding for a flip out couch?
Latitude 0 is offline   Reply With Quote
Old 11-10-2014, 04:26 PM   #2
Have you checked for pin hole leaks. If you can remove it to a yard, lets say, inflate it and run a hose over it with some soapy water.
tyke8319 is offline   Reply With Quote
Old 11-10-2014, 04:47 PM   #3
I have not slept on ours, however different guests have stated it is comfortable. It does not leak air. The key to no leaks is storing it properly. I suggest you contact the manufacturer. Many have done so and have gotten a free replacement or a great discounted price. To answer your question, No, it should not leak air overnight.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
Old 11-10-2014, 04:58 PM   #4
Crusader's Avatar
I have never owned an air mattress for more than one year, that’s has never leaked. That’s the down side of air mattresses.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 11-10-2014, 05:08 PM   #5
mark0224's Avatar
Check the large deflate plug on mine if that plug isn't in good air leaks out. As long as its in good I haven't had a problem. I filled it up and put some weight on it for a week when we weren't using the trailer and it stayed up. If you find a hole in the mattress check the frame for sharp spots in the area of the hole. If you find a sharp spot fix it then cover the entire frame with a movers blanket and replace the matters. We have a coleman mattress in our house for an extra bed if we have company and we have slept on it with no problems.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 11-10-2014, 06:34 PM   #6
Air mattresses are not supposed to be left in campers in freezing weather as when deflated abd folded the cold can cause small cracks in the frozen plastic.
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 11-10-2014, 06:52 PM   #7
We have an air mattress that we've owned for probably 20 years. Still pumps up and hold air. We use it maybe once or twice a year.
2011 Traverse LT, 3.6L, FWD
Old 11-10-2014, 08:17 PM   #8
We have two Aerobed mattresses that have lasted us for about 6 years without fail. One's a "camp" version that comes with a cordless rechargable motor and the other has a built-in motor. We got them at REI but I'm sure you can find them cheaper on Amazon or Wal Mart.
Backcountry is offline   Reply With Quote
air mattress
