Originally Posted by Zargonians
Just corresponded with the owner. What was said above about Google maps was the answer I received. The app still works on my Samsung S9+ (transferred from my S7 about a month ago). The problem is you will not receive any updates. He is giving a $10 coupon for Allstays Pro which is an annual charge unlike the app which was a one time charge. I signed up for a year to check it out. The Pro version is supposed to have more content available. Time will tell I guess. Still available for iPhone and iPad and is being supported with updates. Not an Apple fan so guess I'm outta luck.
I should have put this in my previous post. If you have access to the APK (install file), you can download and install it. You have to set
Settings-->Security-->Unknown Sources (Allow installation of apps from unknown sources): ON.
Then download the file and tap on it.
Some of the standard archives for APKs are
- allfreeapk.com
- apk-dl.com
- apkpure.com
- apkmonk.com
- downloadapk.net
Search for
Allstays at any one of these sites. After you download the file, you may have to look for it in Downloads and tap it to get it to install. If your phone doesn't know what to do when you tap the APK file, search "APK" in the Google Play store and install any of the APK installers.
Be sure to set Security-->Unknown Sources:OFF when you have finished installing.
Please do not start a side discussion on the safety of downloading from other sources. If you don't feel comfortable, just don't do it.
Larry
Larry
