Old 04-27-2009, 07:40 PM   #1
UNIT6AUBURN's Avatar
*&$# Ants
Is there a way to keep ants out of the camper? and what is it with them always using the electric cable to get on??
UNIT6AUBURN is offline   Reply With Quote
Old 04-27-2009, 08:53 PM   #2
powerboatr's Avatar
Vaseline on the cord works
about 1 foot from where it connects to the coach
borax poured on the ground around all points of earth contact will stop em as well
if your under trees, you aren't going to keep em all out,
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 04-28-2009, 06:36 AM   #3
Head Rambler
I usually spray around every ground contact point if I see there's going to be a problem. The power cable and water hoses seem to be the places they like best. I've used Vaseline but it tends to be messy especially if you brush up against it. As powerboatr says, if you're under trees they'll crawl up and fall out of the trees on you (and your camper). Once they were very bad and I even sprayed around the trees that were overhanging the RV. That was a drastic measure and the only time I ever had to do that. Most times a good spray around the power cable and water hose will keep them out.
Gotta go campin!
Old 04-28-2009, 02:43 PM   #4
2x Forest River Owner
naganthunter's Avatar
For years (I'm talking like 20) we (and everyone else) used to use Ajax or Comet on anything that touched the ground when camping at the local beach campgrounds - recently that was deemed harmful to the environment and the practice has been outlawed.
Waitin' for the weekend!
2007 Chevy Silverado
2009 Salem 27RBS Travel Trailer
Formerly camped in a 2007 Flagstaff 228D Pop-Up
naganthunter is offline   Reply With Quote
Old 04-28-2009, 04:42 PM   #5
Old Junior Member
SHOOSTER's Avatar
Might want to try Ortho Home Defense, i'm gonna try it this year, had a friend that told me it works really good on all type of crawling bugs especially ants.
2002 Sandpiper 35RLTS
2005 GMC SIERRA 2500HD XT Cab
And the 2 boy's, 24 lb Kitty Cat & 14 lb Min Pin
Days camped in:
2010 = 72
2011=10
SHOOSTER is offline   Reply With Quote
Old 04-28-2009, 05:32 PM   #6
MRimmer's Avatar
Walmart
product called "terro" is working for us.It in the garden center.
Mike
MRimmer is offline   Reply With Quote
Old 04-28-2009, 08:31 PM   #7
milzat's Avatar
5% Diazinon Insect Killer Granules
or,
5% Sevin Dust
milzat is offline   Reply With Quote
Old 04-28-2009, 08:55 PM   #8
CampeRooo
rthrbelsewhere's Avatar
This year, go with grits.
I couldn't believe it either, but here you go -> http://www.gomestic.com/Do-It-Yourse...t-Killer.62265
Molasses is another one - http://wiki.answers.com/Q/How_do_you...nic_ant_killer
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
rthrbelsewhere is offline   Reply With Quote
Old 04-29-2009, 10:40 AM   #9
powerboatr's Avatar
grits wow i may try that.
thanks for the tip, i like that idea better, and no accidental poisoning of kids or pets
you get GOLD STAR
Old 04-29-2009, 12:27 PM   #10
jaxfl's Avatar
That is a great idea.... if your going to live there. The artical states:
It does not kill on contact or instantly like the traditional ant killers, because grits are not toxic or poisonous. Usually within the first twenty-four hours a noticeable difference can be seen and approaching forty-eight hours the ant colony should be completely destroyed.
Takes 24 - 48 hours to work. Over a weekend I need to keep them out not wait for them to die.
We need a faster method for weekend camping.
jaxfl is offline   Reply With Quote
