Old 08-05-2019, 07:13 PM   #1
And Here's Another Thing I always Forget
The water pump doesn't work when hooked up to shore power!
So I'm out there sanitizing the water system and want to pump the solution through the lines, turn on the water pump and wonder what's broken now!
I always forget that.
Now where are my glasses. Honnneeeyyyyy!
2011 Sunseeker 2860
2006 Honda CR-V
PoppySteve is offline   Reply With Quote
Old 08-05-2019, 07:35 PM   #2
FLY4FUN
Pump vs. shore power?
curious...why does the pump not work when connected to shore power?
14apex is offline   Reply With Quote
Old 08-05-2019, 08:58 PM   #3
Yeah, really.. .mine works when plugged in to shore power.
Maybe it's a Sunseeker thing...
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
walaby is offline   Reply With Quote
Old 08-05-2019, 09:11 PM   #4
Maybe I should post up in the Sunseeker section. Maybe in the motorhome section. Would be good to get a better idea of how that works.
2011 Sunseeker 2860
2006 Honda CR-V
Old 08-06-2019, 09:35 AM   #5
Head Rambler
Unless they have a relay that disconnects the pump when plugged in (which I've never heard of), it should work just like it does not plugged in.
Just because you have power doesn't mean that you're going to have public water.
Do you open the battery disconnect when you're on shore power?
Gotta go campin!
Old 08-06-2019, 12:38 PM   #6
DaGrinch's Avatar
My water pump works on shore power. It's 12 volts.... even my 12 volt lights work on shore power.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 08-06-2019, 01:19 PM   #7
All the 12V items in your unit, pump included, run off the battery. When you are on shore power the only thing that does is allow you to use 120VAC items AC, etc. and it constantly charges your battery. I have a 2016 Forester and they are quite similar. There is no reason your pump shouldn't work when you are connected to shore power. Unless, you turned the battery disconnect to off.
johnshoe is offline   Reply With Quote
Old 08-06-2019, 07:47 PM   #8
Possible answer.
I think it was "city water", and not shore power that was intended.
Old Pilot
Hal Stockton is offline   Reply With Quote
Old 08-06-2019, 08:11 PM   #9
FLY4FUN
Yes...gotta be.
Old 08-07-2019, 05:05 PM   #10
Ok false alarm. Dang I just couldn't hear the pump running!
2011 Sunseeker 2860
2006 Honda CR-V
Old 08-07-2019, 06:50 PM   #11
Honey... where's my hearing aid (sorry.. couldn't resist.. play on your where's my glasses).
Glad it was a false alarm. Got me wondering why I didn't have that feature (grin)
Mike
Old 08-08-2019, 08:44 PM   #12
Love it!
To me this forum is about sharing, learning and having fun. I'm learning and I hope y'all are having some fun.
Cheers!
2011 Sunseeker 2860
2006 Honda CR-V
