Old 03-26-2012, 08:17 AM   #1
trudinator's Avatar
And so it begins....
DH washed the TT yesterday and I started on the inside. It's amazing how dusty, etc. the thing gets from just sitting for a few months. While cleaning the free-standing table, I noticed the glue joint is opening up on the table top. My dealer will get a call today to rectify this, hopefully with a new table.
Then DH decided to un-winterize. Really? On March 25th? Being the skeptic I am, I'm wary of doing it this early. But if we're going to go camping for Eastern weekend, it has to be done. Guess I'll be praying to the weather gods.
2012 Rockwood 8293RKSS
2006 Dodge Ram 2500 5.9L Cummins Turbodiesel 4x4; 2012 Ford Escape 4x4. 3 very pampered cats.
Days camped: 2011: 61; 2012: 66 Days; 2013: 69;2014: 68 2015: 90 Days camped 2016: 34
trudinator is offline   Reply With Quote
Old 03-26-2012, 08:44 AM   #2
acadianbob's Avatar
I share your trepidation on the de-winterizing. We are MN neighbors. I typically don't de-winterize until mid May!! I hope you don't get a sharp freeze. The nice weather gives you spring fever and the urge to get out camping doesn't it?
https://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
Red Green coffee mugs
acadianbob is online now   Reply With Quote
Old 03-26-2012, 08:44 AM   #3
Old car's Avatar
I know what you mean about de-winterizing this time of year. That's what I did over the weekend while the DW reloaded the camper with everything we took out last fall. Last season was our first so we learned there are a few things we took with us that we never used so they are not making the first trip of the season. Easter weekend we are heading south to Lake Texoma.
Lube the axel fittings, sanitized the water system, checked tire pressures, refilled propane and everything lit like it was supposed to, fridge is cooling down. All I need now is for April 5 to get here.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 03-26-2012, 08:51 AM   #4
Wanna Be Camper
SaskCampers's Avatar
We compromised and opended the slides to allow DW to do some cleaning and sit around out there and enjoy the warmth. Dewinterizing will still wait till end of April, I will however install the power tongue jack with 30amp cct breaker and remote disable, Blue Sea battery cutoff and remote power awning controller as well as my wheel well modification to prevent blowout damage. Also taking my wheels in and having steel valve stems installed then balanced with the TPMS sensors installed and the tires refilled with Nitrogen.
John & Deb
2011 Flagstaff V-Lite 30WRLS
SaskCampers is offline   Reply With Quote
Old 03-26-2012, 08:56 AM   #5
acadianbob's Avatar
A guy has to do SOMETHING! I've been out there too. TPMS installed. New tires. Standing there looking at the trailer and other equally productive stuff!!
Old 03-26-2012, 09:08 AM   #6
TURBS's Avatar
I've turned the heat on for a couple nights a few years ago
Just so I knew it was safe.
This time of year one low might be 28 and the next 3
40 .
Old 03-26-2012, 09:16 AM   #7
acadianbob's Avatar
40 .
Yep! Our trailer is stored 60 miles away at our hobby farm so I'm "conservative" on the de-winterizing. You guys should be a good 3 weeks ahead of us here; being down in Iowa.
Old 03-26-2012, 09:17 AM   #8
acadianbob's Avatar
You should be good to go down in KC!
Old 03-26-2012, 10:04 AM   #9
trudinator's Avatar
40 .
Forecast for the next 10 days - 3 nights in the 30's and 7 in the 40's.
Totally unrelated -but has anyone figured out how to get the screens out of the windows on the ends of the slides? The other screens are easily removed, but I can't figure out the two small windows without just yanking them out, and most likely breaking them. I'd post photos, but I'm not at home right now.
