FYI - Below are the specs (I found) for the slide out awning support shown in the picture:
The materials list is as follows:
10 3/4" PVC T's
12 3/4" PVC Caps
12 16" lengths 3/4" PVC pipe
4 30" lengths 3/4" PVC pipe
1 5 1/2" length 3/4" PVC pipe
2 4" lengths 3/4" PVC pipe
2 3" lengths 3/4" PVC pipe
The pieces are all just pressed together the cross sections could be glued if desired. It does require a ladder to slip it in place. This is probably not a good solution for a 1 or 2 night stay, but it does eliminate the water pocket and 90% of the flapping in high winds.
I have tried a beach ball under the topper, but they tend to blow away in high winds and leave the end really susceptable to flapping.
