Old 11-13-2018, 05:40 PM   #21
Kaadk's Avatar
Originally Posted by nomad297 View Post
Softened water is a water heater’s worst enemy. It will also eat an anode in a New York minute.
I don’t know why so many people think that hard water is what kills a water heater. It’s quite the opposite.
Bruce
If you don’t believe me, or you want to get educated on this, look up A.O. Smith’s Tech Center Bulletin 61.
Or, just click on this link: https://www.hotwater.com/lit/bulletin/bulletin61.pdf
Bruce
Good to know. I've always been told it was:
1) Anode rod is used up more when excess impurities are present in the water.
2) Water with excess impurities is 'harder'
So, easy to see how I can mis-interpret that hard water is the cause of anode rod usage. But know I know better.
Old 11-13-2018, 06:35 PM   #22
Just as confused as you
Scrapper's Avatar
Water hardness is determined by the amount of dissolved calcium it contains. Water softeners do not remove dissolved iron, manganese, sulfur, and other minerals the water contains.
The water (private well) at my house has high calcium, iron and manganese. The manganese level is below safe levels but high enough there is a black slime that builds up on the toilet tank walls and needs to be cleaned off periodically.
The water at the cg we are seasonals at is a lot better than the water at my house. The anode is about 85% after 6 yrs. Good to go another 6yrs.
Richard & Jill
Old 11-13-2018, 07:02 PM   #23
Charles Firth's Avatar
My anode is 5 yrs old, and still looks good. I have made it my practice, to drain the heater if it will be sitting any length of time. Several years ago the water sat in the heater for about a month during the hot and humid Virginia summer and got really funky smelling.., so I drain it. I don't know if its right or wrong but it seems to work for me.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
Old 11-14-2018, 11:10 AM   #24
Originally Posted by ard58 View Post
Went to winterize our travel trailer yesterday. Live in south Texas and have unseasonably cold weather down here. Pulled anode rod out of water heater to drain and I was surprised at what I found. The rod is totally used up. I've read some of you have not replaced yet and your trailers are 3, 4 years old and some older. Lucky you. Our trailer is only 16 months old but from what I saw I am going to start replacing it every year.
They do make aluminum rods for places where the water is real bad .
MR.M is offline   Reply With Quote
Old 11-15-2018, 05:00 AM   #25
nomad297's Avatar
Can you define “real bad”, please.
Bruce
Old 11-15-2018, 09:51 AM   #26
Bruce
According to my dad, when he was growing up (50's era) their tap water came out looking like iced tea. I think that is the definition of "real bad".
Iwritecode is offline   Reply With Quote
Old 11-15-2018, 10:29 AM   #27
Bruce
real bad is where it eats up your anode rod in 1 season
anode
