You have to try to hold the far end of the rod UP (i.e., level) while inserting and turning it. (If you just stick it in, it will droop and won't be square on the threads.) It can be quite a trick. You might try putting your socket back on it; if it's "tight enough" on the rod, it might give you more to hold onto while trying to keep the other end of the rod up. The trick is to keep it square to the threads.
2011 Traverse LT, 3.6L, FWD
