Originally Posted by NMWildcat
I disagree! How can the only correct answer be the placard? You make it sound like running the tire with max cold psi molded on the tire is a bad thing. Every tire has it, and is readily available to the OP. I know my rig is loaded heavier on some trips than others. I'm not going to weigh it and adjust tire pressure accordingly. So I run at the tires max cold psi and don't worry about it. Why do you not consider this as an acceptable practice?
There is nothing wrong with using maximum inflation pressures with RV trailer tires. However, in the absents of supporting information the recommended tire inflation pressure for the OE tires depicted on the tire placard is their correct inflation pressure.
Until someone challenges the validity of the OPs tire placard the 80 psi is correct. FMVSS standards and tire industry standards both agree on that.
Once the trailer has been scaled and some weights have been established, the recommended inflation pressures can be increased up to and including the max value on the tires sidewalls, but never lower than 80 psi.
One important thing to remember is the G614 tire is an LT tire and uses load inflation charts developed for LT only.
