10-18-2016, 09:36 PM
Another tire question
I know this has probably been asked and I have read a lot of threads on tire pressures. But here goes so be nice!
On my cedar creek 36B4 the tire placard says I should be running 80psi for my
Goodyear G614 RST LT235/85R/16G, since I got it in 2012 my dealer told me to run my tires at the max psi of 110. Which I have been doing. However, it seems that might be too much. All our stuff keeps bouncing around and one of our wall boards keeps popping out. So maybe I should be running the lower psi for a less harsh ride?
Thoughts from the experts would be greatly appreciated.
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded
Loving Life
10-19-2016, 06:33 AM
Insert witty title here
I would run them at the max PSI that is shown on the tire wall. This pressure should be set when the tire is cold.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
10-19-2016, 06:42 AM
Underinflated tires cause blowouts (or whatever the real name is). Inflate to max pressure.
FROG AR-0019-242
10-19-2016, 07:23 AM
Always Learning
This sounds like an unintended consequence of a major tire upgrade. The harder tires likely transfer more jolts to the camper.
I'd run max pressure (maybe a little less- like 100psi) but would also add shocks to the camper to ease the road impacts from being transferred so harshly.
10-19-2016, 07:31 AM
Agree with what the other folks have said and think the addition of shocks on the larger trailers is a great idea
Retired Navy
2016 Flagstaff 26 FKWS
10-19-2016, 10:26 AM
Be aware that the addition of shocks will make the trailer bounce more when walking around inside.
10-19-2016, 10:36 AM
Why?
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
10-19-2016, 10:40 AM
Always Learning
Not for me it didn't - I found no difference before and after.
10-19-2016, 10:41 AM
Check the manufacturer's psi load requirement. Do you know your trailer weight? They say you can drop down to the load requirement, but myself I disagree no matter what they say, I run at the stamp CP PSI. I agree underinflated tires cause the major problem.. PS: by the way if your sticker says 80 PSI for that exact tire your should be okay. The big problem is when people buy new tires, THEN THE DILEMMAS.
Coachmen M/H
Concord
2018 / 300 DSC
10-19-2016, 10:54 AM
And where do you get this information? Shocks neither add nor subtract to trailer bounce when the trailer is not moving. Voice of experience!
10-19-2016, 02:35 PM
I read this same type of thing before and the solution was....to have those tires balanced.
I know its a big debate whether you should or shouldn't but this is not your question.
The other persons solution was to have them balanced and that solved their problem. Its a pretty cheap solution as well. Less than the installation of shocks. The worse that happens is nothing.
10-20-2016, 07:35 AM
OK, so the the 614s are 14 ply with a 110 inflation pressure. OEM tires are 10 ply with Max inflation of 80 psi. That's the difference. Now, trailer tires should allways be inflated to the max pressure for the tire, otherwise heats builds causing tire failure. As for shocks, they don't affect bounce while parked, how could they? If anything they would help as that's what they are designed to do. At any rate I have shocks, equa flex equalizers and 14 ply tires as well. The tires were added last and I can tell no difference in things getting moved around. I will say shocks helped the most with ride quality. No more endless bounce. And yes Balance Tires.
10-20-2016, 08:02 AM
Back to the OPs question, Keep the tires at the designed pressure JMHO
Retired Navy
10-20-2016, 10:03 AM
Can you define "designed pressure"?
2015 F350 6.7
10-20-2016, 12:29 PM
for trailer tires the max pressure on the sidewall is designed pressure (my term not the tire company)
Retired Navy
10-20-2016, 12:51 PM
This is literally the opposite of what shocks do.
10-20-2016, 12:54 PM
Understood, thanks.
2015 F350 6.7
10-20-2016, 02:34 PM
The sticker and the tires match. So the 80 psi would be what FR recommends. See my dilemma? Most everyone says Max psi, but manufacturer says other wise... 30 psi is a big difference. Anyone have a # I could call and ask FR?
Loving Life
10-20-2016, 03:27 PM
Always Learning
Should be in here:
https://dealers.forestriverinc.com/D...nformation.pdf
10-20-2016, 04:37 PM
The sizes maybe the same, but the plies are more on the 614s. 14ply vs 10 ply. 14 ply tires in a 235 take 110 psi...10 ply tires in a 235 take 80 psi.
