Old 09-27-2015, 06:37 PM   #1
Anti Freeze in water holdig tank
Hi Everyone,
In the mid-west his fall weather is great for camping.
As many of us get ready to prepare our RV's for winter, I plan to drain all water lines and put anti-freeze in them. However, I want to fill water holding tank for use with the toilets during the winter when weather permits me to get to the camper.
How much anti freeze do you think I will need to put into the holding tanks to keep from freezing?
We can take showers in the "shower house" and use portable water for brushing teeth and cooking.
We will remember to put anti freeze in bath "p" trap after each visit to the camper and know not to use kitchen sink or shower. As well as anti freeze on the inside toilet ring/gasket.
I think, I have ~35-50 gallon holding tank.
Has anyone done this before?
Thanks for your comments.
rienzo is offline   Reply With Quote
Old 09-27-2015, 06:50 PM   #2
gashog's Avatar
IMO, don't put antifreeze in your fresh water holding tank. It will take you forever next spring to get it all out. Do a complete winterize, including draining your fresh water tank. If you're going to do some cold weather camping, bring a couple jugs of RV antifreeze, use it to flush your toilet. Just my option, even though I don't do the cold weather camping.. others that do might have a better suggestion.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 09-28-2015, 09:06 AM   #3
WFD
I agree....if you store RV antifreeze in your fresh water tank for some time, you will be dealing with that forever.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 09-28-2015, 10:41 AM   #4
oldgold's Avatar
Why not use a compressor and just blow out the lines each time when you're breaking down the camper? We camp down here all winter even go up to the mountains. Lowest temps while camping so far was 15 at night and 30 daytime. No issues so far. Before you leave just blow out the lines and then you don't need antifreeze at all except for p traps.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 09-28-2015, 12:08 PM   #5
I blow out lines twice. Anti freeze in p traps only. No problems. Remember outside shower.
Harkerr is offline   Reply With Quote
Old 09-28-2015, 07:52 PM   #6
Agree! Something I might try this winter after draining the lines and keep water in the fresh water tank, is to lay an electric blanked over the tank, which is located below our bed. I can plug it in whenever I think it'll get down below 28 or so. The blanket will also cover the pump. I'll also put a small, heater inside just to keep the camper somewhat warm.
gfarmcafe is offline   Reply With Quote
Old 09-28-2015, 08:10 PM   #7
deartruc's Avatar
well, how about bringing a 5 gal water jug and pull it in using your antifreeze inlet to your pump? That way you can drain the fw tank and let it dry.
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
tank, water
