Old 10-03-2015, 02:19 PM   #1
cwppwc's Avatar
Thumbs up Antifreeze
Just a heads up that Ace Hardware has RV/Marine antifreeze on sale for $1.99 a gallon; limited to first two gallons per transaction with the Ace Rewards card. When I took up 4 gallons, the checker informed me about the limit and asked if he could do two transactions so I would get the discount on all four gallons. Awesome! Love my local Ace store!
2016 Open Range 319RLS
2015 Ram 2500 Laramie Longhorn Limited 6.7 Diesel
cwppwc is offline   Reply With Quote
Old 10-18-2015, 05:15 PM   #2
rwmurphy's Avatar
Purchased 6 gallons of antifreeze at the ace store. Read in a thread to put some in a cup and place it into the freezer to see how good it is. I did so and it froze in 2 days. No wonder it's $1.99. Returned it.
rwmurphy is offline   Reply With Quote
Old 10-18-2015, 05:24 PM   #3
Flybob's Avatar
You need to read the specs. For RV antifreeze there is a big difference between the freeze point and the expansion point. The freeze is not what does the damage, it it the expansion after freezing. Check the spec and you should see a spec something to the effect of expansion temp. It is common for RV antifreeze to freeze but is doesn't expand at that temp as water does.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-18-2015, 05:24 PM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
If it Marine/RV antifreeze it should not freeze Container says it's good to -50 but slush will occur. I've use this for all my campers for over 30 years and never had an issue. However found a tad cheaper at Walley world. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 10-18-2015, 05:24 PM   #5
Ford Idaho's Avatar
Prestone was under 4 bucks a gallon at Walmart.
I only need 2 gallons to get the lite done.
Old 10-18-2015, 05:26 PM   #6
aceinspp's Avatar
Are you saying you are using regular antifreeze? Not good. Later RJD
Days camped 2017 62
Days camped 2018 18
Old 10-18-2015, 05:43 PM   #7
Ford Idaho's Avatar
Yes, "regular" pink AF!
From yesterday.
Old 10-18-2015, 10:43 PM   #8
It worth noting that not all Plumbing AF is the same.
Cheap stuff contains ethanol, is flammable, and can taint the taste in the plumbing system.
Perferred products such as Camco WinterBan or FreezeBan uses Propylene Glycol, are not flammable, and will not affect the taste in waterlines or plumbing.
I personally will only use Propylene Glycol in my rig ...
2009 Salem PT 403FB
2005 Ford XLT Supercrew
Cookies & Chips is offline   Reply With Quote
Old 10-19-2015, 12:46 AM   #9
cwppwc's Avatar
The $1.99 (sale) antifreeze at Ace Hardware is Camco Artic Ban for freshwater systems which is propylene glycol but also has ethyl alcohol.
Camco 1 Gallon Artic-Ban RV Anti-Freeze (30807) - Engine Antifreeze - Ace Hardware
Old 10-19-2015, 02:35 AM   #10
Witch Doctor's Avatar
If it made by Camco then it would be fine to use. That showed good to -50 degrees. Camco the leader in RV stuff would not put anything in it to leave a residue. I wouldn't hesitate to use it.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
antifreeze
