Old 10-16-2015, 01:11 PM   #1
Retired
MainelyUS's Avatar
Antifreeze Inlet sticker
Before I begin the winterizing our Windjammer 2618W I want to make sure I locate all the parts and pieces before I begin the process.
I started by reading the Antifreeze Input sticker on the rear to the TT (pic#1) and it stated to 1st close valve to tank, 2nd to open the valve to the inlet....
Upon opening the water pump/filter compartment I could only locate one valve (pic#2)
I assume by turning the valve handle to the up position this is "opening the valve to the [antifreeze] inlet (pic#3).
Two questions: 1st, Am I correct in this assumption 2nd where is the valve I am supposed to close to the tank?
Yes, I have read the manuals (on-line and hard copies) and searched the FRF archives.
Thank you for your inputs.
Happy Trails to all you Snowbirds
pic#1Click image for larger version
Name:	Antifreeze inlet sticker.jpg
pic#2Click image for larger version
Name:	Valve handle down pos.jpg
Pic#3Click image for larger version
Name:	Valve handle up pos.jpg
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
MainelyUS is online now   Reply With Quote
Old 10-16-2015, 01:18 PM   #2
fonzie's Avatar
The one valve does both function......in picture #3 the pump will draw from the anti-freeze inlet.....
Fonzie
Old 10-16-2015, 01:19 PM   #3
nomad297's Avatar
That single valve will do both. It will close the tank line and open the antifreeze suction line. Some systems have two valves. Yours has one.
Buce
Old 10-16-2015, 01:24 PM   #4
Retired
MainelyUS's Avatar
fonzie & nomad297
Thanks for the quick reply.
I shall add this page to my improved owner's manual.
Have a great day.
2017 Columbus 340RK
Old 10-16-2015, 01:30 PM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
Buce
Mine is set up the same way on the V-Lite. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
antifreeze
