Old 03-15-2013, 03:17 PM   #11
If you have two batteries and run them both down does that mean you have to run the generator twice as long to charge back up?
comfun1 is offline   Reply With Quote
Old 03-15-2013, 03:19 PM   #12
TURBS's Avatar
It may take longer .... yes
Old 03-15-2013, 03:47 PM   #13
Fulltime family RVer
Care to elaborate on that at all? Does it have to do with the charger being used?
Old 03-15-2013, 04:21 PM   #14
There has been alot of discussion on this subject from time to time. There was one thread just recently that got down into the nitty gritty in terms of 12v systems and power management... Battery choices, charging, chargers, leds, battery set ups, and generators. Do a search on this forum and I think you'll find some very informative info.
grayfox is offline   Reply With Quote
Old 03-15-2013, 04:56 PM   #15
TURBS's Avatar
Lets say you use a 3 amp hour charger which in theory should charge a single battery 3 amps an hour now take two batteries and charge them with the same 3 amp hour charger ..
http://www.csgnetwork.com/batterychgcalc.html
Old 03-15-2013, 05:48 PM   #16
[QUOTE=f1100turbo;326265]Lets say you use a 3 amp hour charger which in theory should charge a single battery 3 amps an hour now take two batteries and charge them with the same 3 amp hour charger ..
Battery Charge Time Calculator
That's a good'n Turbs... Thanks
RICK
Old 03-15-2013, 05:53 PM   #17
TURBS's Avatar
[QUOTE=grayfox;326304]
RICK
It doesn't EXACTLY work that way but it gets the point across.
Old 03-15-2013, 06:23 PM   #18
You absolutely want the second battery! For $75 at Wal Mart and $20 for joining cables you can't go wrong. Being stuck inside during bad weather spells, camping later in season when you are inside earlier, having guests overnight, you don't don't want to be bothered with worrying if the battery is going to go dead.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 03-15-2013, 06:41 PM   #19
Where can u get joining cables and how do I know what size charger I have?
Horns07 is offline   Reply With Quote
Old 03-15-2013, 06:42 PM   #20
TURBS's Avatar
sent pm
