Old 01-25-2016, 07:53 PM   #1
Anyone ever have a table that is too small to convert to a bed?
We just purchased a brand new 2016 Vibe 250BHS and everything was great until we tried to convert the dinette table into a bed. The opening between the seats is 27 inches but the table is only 26 inches so it won't work. Contacted the dealer and they are looking into this but just wanted to see if anyone else ever had this issue. This is our first travel so hopefully this is the only setback and not a sign of things to come.
2016 Vibe 250BHS
2015 Chevy Silverado 2500 HD w/ 6.0L gas engine
Husky Center Line TS Hitch.
LJS1211 is offline   Reply With Quote
Old 01-25-2016, 08:04 PM   #2
There are supposed to be braces screwed to the front of the seat benches that the table top rests on. Could the factory have forgotten to add the braces? If that is the case its a relatively easy fix.
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 01-25-2016, 09:35 PM   #3
The braces are there which is the frustrating part. I can always remove them and add bigger ones but hate that the factory screwed up. Waiting to see if the dealer can get me a bigger table.
Old 01-26-2016, 05:50 AM   #4
davel1971's Avatar
Likely the dinnette is 1 inch too far apart. The cure will likely be bigger supports, not a bigger table
David & Lynn
Old 01-26-2016, 06:10 AM   #5
RSchleder's Avatar
This post makes sense unless the booth is U-shaped. If not, moving the booths closer together should not be a big deal, simply elongating the bolt holes in the bottom wooden braces should allow one, or both booths to be slid closer together.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 01-26-2016, 12:32 PM   #6
yes the unit my brother purchased a 2014 Keystone passport had the same table problem, took it back as part of some warranty work.
Angels is offline   Reply With Quote
Old 01-26-2016, 02:05 PM   #7
B Mac
I picked up a bunch of 1x6 and 1x8 from the scrap pile at Home Depot and cut them to length. I just drop the table to the floor and use the boards.
bbbymac is offline   Reply With Quote
Old 01-26-2016, 02:39 PM   #8
Left Coast
I had to move one end of one bench 1".....unscrew from floor and move it....
Old 01-26-2016, 05:12 PM   #9
The Tudors
TroyATudor's Avatar
Mine was too small
I have a 2014 Salem Cruise Lite 261BHXL and that's what I found when I went to convert the table to a bed. I ended up buying an extra table tube, taking it to a friend who is a machinist, and had two small tubes made for it just long enough to bring the table up to the level of the benches. When I make the bed with the table, the small tubes provide better support than the small cleats they put on the sides of the benches. Plus I no longer scrape my shins on the cleats when I slide in to sit at the table.
Jeep Commander 5.7 HEMI 3.73s K&N Cold Air Intake / Salem Cruise Lite 261BHXL
TroyATudor is offline   Reply With Quote
Old 01-26-2016, 06:03 PM   #10
Mine just barely rested on the rails. I purchased some 1x2 removed the factory rails and attached the 1x2 behind it and reattached the original rails over them. No one notices as the cushions cover the top and the face is covered by the factory rails.
Kf4mnc is offline   Reply With Quote
bed
