Old 12-28-2006, 03:48 PM   #11
Cool Water System Sanitation
It is not uncommon for RV owner to complain of bad water. The first sign of a contaminated water system is usually a bad taste, followed by strange orders emanating from the water supply. Bacteria may have built up in the water tank, especially if the water tank's supply has not been used frequently and has not been replenished with fresh, clean water on a regular basis. When a rig comes out of storage or is being used extensively on a city-water connection, the tank and entire water system should be sanitized before use. Some of the bacterial buildup can cause serious illness; don't take chances!
Drain the water tank completely, then refill halfway with clean, fresh water
Mix cup of household bleach for every 15 gallons of tank capacity in a container with a gallon or two of clean water.
Pour this mixture into the water tank.
Top off the water tank with fresh water. Drive the rig around the block to mix the solution.
Pump water through each faucet so that all the lines are filled with the water/bleach
The hot-water tank holds at least 6 gallons of water. Run the hot-water faucets until this much solution has passed to insure that the old water has been purged from the hot-water tank, and it is now filled with the water/bleach solution from the water tank.
Let the water stand for several hours.
Drain the entire water system, hot-water tank included.
To remove the bleach odor, mix cup of baking soda with a gallon of water and pour into the freshwater tank.
Fill the tank completely and pump this solution through the water heater and the rest of the water lines. This solution can sit in the system for a few days. Driving the rig around the block will slosh water around and thoroughly clean the tank.
Drain the entire system and refill with fresh, clean water.
copout67 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Drain Valves Newfie General Travel Trailer & Fifth Wheel Discussion 1 04-08-2007 09:57 PM
water pump problem Gene Lueg General Community Discussions 3 09-06-2006 01:30 PM
