05-14-2018, 05:37 AM
Anyone Know How To Remove Radio ?
Hi!
I have a 2015 Wolf Pup 17RP toy hauler...It's a great little trailer for the price, but I want to upgrade a few items.
I noticed last summer the the CD player stopped working and when I got it out of storage a couple weeks ago I noticed that the digital display isn't working. I'm not a big fan of the radio anyway so I want to replace it. I can't figure out how to remove it...anyone have instructions on how to do so ?
Thanks !
05-14-2018, 05:41 AM
What model Radio? If you’re not sure, you can post a picture. That’ll help us know how to help.
If it happens to be a Genesis GT-2.0, then there are trim pieces that snap off on either side of the radio, exposing the screws that holds it in.
05-14-2018, 06:16 AM
I think its a Linear Series RV4000 ? I can't find the owners manual. The quality is pretty shoddy...
05-14-2018, 06:23 AM
Ok, that helps. Does it look like this?
If so, this link seems to have a user manual:
http://magnadyne.com/linear-series-r...ower-receiver/
In that, it includes installation instructions that indicate there’s a trim ring around the unit that comes off.
05-14-2018, 07:39 AM
Yep! That's the one... I was able to find the owners manual and it looks like the outer trim piece comes off to reveal the screws. Looks like it'll be an easy swap...all the speaker/power wires are clearly marked.
The $59 JVC CD/MP3 player I installed on my hot tub is far better quality than this RV unit. ;-)
05-14-2018, 07:40 AM
Much obliged ! I'll post pics when I get the new unit installed. I'll probably put a better quality AC unit in as well.
05-14-2018, 07:59 AM
Are you going with another rv type radio or going to a car stereo ? Im leaning towards going to a decent car stereo and upgrading the speakers .
TV:GMC 2500HD Duramax
TT: 2015 Wildwood 21rbs
05-14-2018, 09:31 AM
I'm probably going to go with an aftermarket unit with built in bluetooth...The only thing is, the camper has indoor and outdoor speakers. I'd like to find a stereo with A, B or AB speaker options.
05-14-2018, 09:52 AM
Might be able to find a 'rear zone' option. Back when I had my Pioneer AVIC-Z1 this was available, for outputting the DVD to the backseat while the main speakers would run driver-safe sources, like the radio. I always figured if the GT-2.0 in the Flagstaff ever gave up the ghost I'd replace it with something like that. That way, I could still listen to the radio outside when the kids were watching a DVD inside.
05-14-2018, 05:08 PM
Home theater
The stereo in our 2007 Cherokee is right next to the shelf for the TV. I put a 5.1 channel home theater under the TV and connected it to the interior trailer speaker. It has FM and 5.1 audio from the TV and CD/DVD, Aux In for playing from from phones/iPods, and a USB slot for playing audio or showing photos.
The original stereo is still installed and can play AM/FM/Weather channel through the outside speakers (B channel). It also has Aux in for playing from phones/iPods, and Aux out.
If I cared to, I could spend a minute or two and connect the the home theater's Aux Out to the original stereo's Aux in, and play the home theater outside. And another minute or two to connect the original stereo's Aux Out to the home theater's Aux In to play the console's audio inside. I haven't done these two simple mods because I don't think DW could get the settings straight and audio isn't a big thing with me.
Larry
05-14-2018, 05:19 PM
Love the Bluetooth option. I can sit outside (or inside) and wirelessly play all my music that's on my phone, and even control the volume from the phone. This is through a Jensen unit on the RV.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
05-14-2018, 05:57 PM
Bene Gesserit Rule
Pretty easy. Pry off the surround to expose the mounting screws. You will probably have to cut-n-join the wires because this radio has custom plugs for the connections. No big deal. They are easily identified.
I swapped mine for an Alpine car radio with DVD player and made the new mounting plate to fit the original surround.
05-14-2018, 08:42 PM
Thanks! This is probably the option I'll go with, should be straightforward
05-14-2018, 09:38 PM
our stereo was toast. We installed this one, it works great and has A B & C speaker outputs
https://www.ebay.com/sch/i.html?_fro...tereo&_sacat=0
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
05-15-2018, 01:20 AM
Bene Gesserit Rule
Because you will have to cut wires to make the new connections, it will give you the chance to swap some around to make speaker selection more logical, at least that was what I needed to do. It will certainly stop the outside speakers from continually failing (a fault with the radio not the speakers or wiring).
