Old 11-16-2010, 09:29 AM   #1
Exclamation Are all or other FR TT built the same as the Surveyor SV-291
I have a 2011 Rockwood 2702ss, I have been reading problems with slides leaking on the Surveyor TT. I am a little concerned that my trailer could or will have these issues, (leaking under bottom, water pooling at gasket, ect)
anyone have any thoughts on this?
We have had our slide out during some pretty strong heavy rains with no leaks present........yet
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 11-16-2010, 09:40 AM   #2
Check the seals at the inside bottom corners of the slide... they fill up with water and hide the damage, I had to flip mine inside out. Check my pictures on my leak thread I posted and you will see what I mean. I also thought I did not have a leak and found it by pure chance. There are at least two more complaints jsut on this forum as you must have come across them..
Is your slide a full one or like a cutout with the bottom getting inside the trailer ?
2009 Ford F-150 XLT/XTR 5.4l, CrewCab. long bed
2011 Surveyor SV-291
Goomph is offline   Reply With Quote
Old 11-16-2010, 10:10 AM   #3
"Is your slide a full one or like a cutout with the bottom getting inside the trailer ? " What do you mean here?
not really sure I can actual see my bottom inside corner on one side it is part of my kitchen.....
Old 11-16-2010, 10:50 AM   #4
Yup you have the same design. Check those bottom seals for water, put your fingers in there you can do it. Any wetness inside and you know what to do
Looks like your trailer is very similar to mine You have a U dinette ! and the bunkbeds are reversed ! I love the direct outside access to the washroom
Old 11-16-2010, 11:50 AM   #5
"Yup you have the same design. Check those bottom seals for water, put your fingers in there you can do it. Any wetness inside and you know what to do "
How do I fee for this in the lower corners outside? If there is wetness what is it I need to do, Goomph you seem to be the expert on this topic...?
Old 11-16-2010, 11:53 AM   #6
You need to check the bottom inside corners of the slide out. The parts which are completely inside of the unit when the slide is in. You will see the white seal going down on the side to the bottom and fold underneath. get on your knees aor lie down and look under the slide. There you will see the rail coming from the slide and the seal meeting it. If the bottom of your slide is enclosed, then I don't know. Mine is wide open.
Old 11-16-2010, 11:57 AM   #7
Goomph, I understand your pain but is there any chance you could shoot a couple more pics.......?
Old 11-16-2010, 12:01 PM   #8
I will link to some other pictures later today where you will get a better idea where it is.
Old 11-16-2010, 12:10 PM   #9
awesome..... so is the leak an issue only when slide in?
Do you have your TT under any cover or out building?
Old 11-16-2010, 02:12 PM   #10
It leaks when it the slide is out. But another SV-291 member reported that it leaked while it was in. I am eprsonally thinkign that it ahd accumulated when it was in and then spilled later when it was in. That's how I found mine was leaking. No sign of a leak. I take it for a ride to adjust my prodigy. Lots of braking some harsh of course. I open the door and water everywhere .... And when I sa water over the sink waste water which is high I said to myself where did this come from ? And toucjed the seal and there it was hiding nicely and rotting my slide's edges secretlly/
Here are the pictures ...
Rear of the slide oven/stove area. See the access panel is taken out
Getting closer to the access panel
Under the sink looking through the access panel. You see the bottom of the seal there it is white :
Close up of the water collection area :
Put your hand right into that seal it is open as you can see.
