Old 07-11-2016, 01:14 PM   #11
TURBS's Avatar
Lippert even makes the adapter to go on the hydraulic pad for the JT strong arms " which they own"
iVe seen several jt strongarms on the 6 point level up hydraulic system.
My jt's on my mechanical 6 point auto level make it rock solid.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-11-2016, 01:15 PM   #12
TURBS's Avatar
Here's the adapter.
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-11-2016, 01:30 PM   #13
Witch Doctor's Avatar
Originally Posted by BandJCarm View Post
Doesn't Lippert themselves sell JT Strongarms??
How can they make such a claim.
Here is a direct reply/email I got from owner of SteadyFast system from an inquiry I sent.
Our system works really well on the LCI six point auto leveling system. It will remove 90-95% of the movement which makes the RV feel real solid. Whether you need it or not depends on your sensitivity to the trailer movement. I would recommend you try the trailer and if it moves more than your are comfortable with, we can take care of the movement.
I was told by Lippert that I can not use this system. First of all you either have to weld an eye to the pad or buy pads that have a connection such as the BIG FOOT system has for sale we are not talking apples to apples. The picture that is shown is for an electrical system not HYDRAULIC. The electrical just moves up and down. I had JT ARM STRONG on my old system before lippert installed the new system. They took them off and stated that they would not work with the level up system because it was hydraulic. If it was electrical it would work. I'm not convinced that it would not work but the cost to replace a cylinder I will take there word. I asked if I welded eyes in or bought Big Foot Pads would it work they said no, they wouldn't warranty the system. To be honest I have never really seen the cylinder spin, but it is hard to tell. I spent 3400.00 in Goshen to have it installed at the factory. I love it and would never buy another trailer without it. You just have to figure out what is best for you to stop the movement as has been mentioned in these post. Height is the biggest problem with the rams. The lower the rams the more stable it becomes, I have had it for two years now and played around with it alot, my DW is very sensitive to movement. So this is what I found to do to stop 90% of it. AS I stated above. A person can do as they please after warrenty but then it is on your dime. (Sometimes I think it the booze and not movement but that is between us the 1000 plus members)
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-11-2016, 02:44 PM   #14
NMWildcat's Avatar
After all this talk about the steadyfast system I revisited their site and liked what I saw. I originally didn't buy as they really had no solution for the 6 point hydraulic leveler round footpad (too much redneck engineering to get it to work).
Now they have a flat head bolt kit that looks promising. Why they just don't have a replacement elephant foot that has the correct attachments is beyond me. Guess flat head bolts are cheaper.
The argument that the steadyfast won't allow the piston rod to turn in the cylinder makes no sense to me. My footpads turn while the rod is held steady and the rod can also turn in the cylinder. So I don't see how holding the footpad stationary will affect piston rod turning. And none of the piston rods turn on my front end loader cylinders so I'm confused as to why they think that is necessary.
So as soon as I get my allowance I'm ordering the steadyfast and selling all my other devices!
I mainly used the universal stabilizers. The aluminum ones with the ratchet strap. They work on the same principle as steadyfast but can be a pain to get setup. But I bought 3 of them from the original guy before Valterra bought him out and CW tripled the price!! I might be able to make some money!! LOL!! I figure I'll just give my x-chocks to my buddy that always says he's gonna get some and then never does.
Thanks for the discussion on the steadyfast system!!!
Woohoo... another worthwhile project
Scott and Liz - Southern NM
Old 07-11-2016, 03:01 PM   #15
I have the point hydraulic system, also chicks front and back of tires as suggested for hooking up to and and disconnecting from trailer also use xchocks and a tripod. Takes out 90% of the movement. My landing gear cylinders do turn when even I lower them.
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
Dinostop is offline   Reply With Quote
Old 07-11-2016, 03:34 PM   #16
dieselguy's Avatar
I too talked to a Lippert tech about installing the JT's on my 6 point hydraulic level up system. I have worked with hydraulics for better than 30 years and didn't quite buy the concern about not allowing the hydraulic cylinder rods to spin. We have several dozen hydraulic cylinders at work mounted in such a way that the rod cannot rotate with no issue. I ordered the adaptors that Turbs showed a few posts up ... drilled and countersunk fastner holes in the level up round feet and installed a set of JT's like I had on my SOB's. It's been better than a year now with rock solid results and no cylinder issues. Like said in other posts ... the more you reduce the amount of cylinder rod extension, the more stable your unit will be without something like JT's or Steady Fast.
dieselguy is offline   Reply With Quote
Old 07-11-2016, 03:46 PM   #17
TURBS's Avatar
Automatic Leveling Question
Yes the adapters I show are not weld on, they bolt on to the pad like diesel guy said for the hyd system.
The electric system mounts entirely different.
The cylinders do not need to rotate that's horse crap.
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-11-2016, 03:59 PM   #18
NMWildcat's Avatar
I know you have the strong arms Turbs, but how do you think they compare to steadyfast? To me the strongarms look a little more sturdy but I like the wing nut tightener system of steadyfast. Any thoughts?
Old 07-11-2016, 04:05 PM   #19
TURBS's Avatar
I've not seen steady fast up close so I'd hate to comment.
2015 Columbus 320RS
2008 2500HD Duramax
leveling
