Old 08-28-2016, 08:58 PM   #11
danielabram71's Avatar
Yes I have heard that too many campers are in a park if it is not wired good that you can get low voltage. But in my opinion I think it would have effected more then the awning lights.
1014 1500 GMC
2015 solaire 267bhsk
danielabram71 is offline   Reply With Quote
Old 08-28-2016, 09:01 PM   #12
Thought the same thing. I got it to come on for a short time , funny thing was I was flipping the other light switch beside it.
trcannon is offline   Reply With Quote
Old 08-28-2016, 09:03 PM   #13
crunchman12001's Avatar
Originally Posted by trcannon View Post
Have at storage facility
Ok, no problem. LED awning lights are very basic.
Do you have a switch to activate them or do you plug them in to an outlet?
Since you are new to Rv'ing, the best investment you can do to protect your Trailer is to buy this. Buy it as soon as you can afford it. It will save your trailer from many electrical issues.
EMS-PT30C 30 Amp Portable EMS
2017 Salem Villa Estate 395RET- Ordered - Coming soon
2015 F-250 FX4
crunchman12001 is online now   Reply With Quote
Old 08-28-2016, 09:04 PM   #14
Switch
Old 08-28-2016, 09:09 PM   #15
Flybob's Avatar
A loaded campground can cause low AC voltage and if low enough can damage the AC compressor. The lights ( including awning lights) are 12V and not impacted by low AC voltage unless battery voltage is low .
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-28-2016, 09:12 PM   #16
Ok, battery was full, guess I have to contact the dealer.
Old 08-28-2016, 09:12 PM   #17
Ok thanks for the explanation flybob
1014 1500 GMC
Old 08-28-2016, 09:13 PM   #18
Thank you everyone!
Old 08-28-2016, 09:28 PM   #19
Switch
Ok, this points us in a direction. (Stop me if I am asuuming the wrong direction)
You were plugged in on 30amp power, with a switched source to turn lights on?
The lights are most likely run on 12V but if plugged in your inverter would charge battery so that discounts dead battery.
There is no reason your lights should have stopped working due to low park power.
There are only 3 things that could fail, if everything else worked.
Light strip is bad.
Controller is bad.
Remote is bad. (If included.)
The lights may have failed due to a number of reasons that my have been coincidence with the the park filling up. You will need to plug the unit in again and see if the lights work.
Please follow up to see if the lights are still not working when you go out again.
2015 F-250 FX4
Old 08-28-2016, 09:32 PM   #20
I was flipping the other light switch and it was affecting the LED light
awning, light
