Old 08-28-2016, 08:24 PM   #1
Awning lights
Just got back from a week of camping. Had a slight problem with the awning lights. They worked all week, until Friday when all the spots filled up. Played with the switches, turning off and on. Would work for a brief moment then cutoff. Is this normal, is there a quick fix? Fuses were fine as well, any help would be appreciated, thank you.
trcannon is offline   Reply With Quote
Old 08-28-2016, 08:30 PM   #2
crunchman12001's Avatar
What is the year, model and make of your trailer or pop up?
How was the rest of the trailer power?
Were you plugged in to shore power or using battery only?
If shore power, how was the air conditioner?
Do you use a PI EMS? What was the volts coming into the trailer?
2017 Salem Villa Estate 395RET- Ordered - Coming soon
2015 F-250 FX4
Old 08-28-2016, 08:35 PM   #3
Everything else was fine, I don't know what the volts were. 30 amp plug. Was the only thing that stopped working.
Old 08-28-2016, 08:40 PM   #4
Were you plugged in or battery? What do you own?
Edit. Ok, you were plugged in....
2015 F-250 FX4
Old 08-28-2016, 08:43 PM   #5
Salem 30 kqbss , plugged in. Only been rv'ing for a couple of months.
Old 08-28-2016, 08:47 PM   #6
Ok, we're here to help everyone.
Have you plugged in now that you are home and do the awning lights work now?
What year is your trailer?
2015 F-250 FX4
Old 08-28-2016, 08:48 PM   #7
danielabram71's Avatar
How long have you had your camper? If you got it new I would go back to the dealer. If not I would try to get help on here. They are good. And if nothing else may have to see a dealer. Good luck
1014 1500 GMC
2015 solaire 267bhsk
danielabram71 is offline   Reply With Quote
Old 08-28-2016, 08:48 PM   #8
Flybob's Avatar
Some units have a step light on same switch. If so it step light working?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-28-2016, 08:49 PM   #9
Have at storage facility
Old 08-28-2016, 08:53 PM   #10
Got in July, no step lights, heard that when the campground is full there can be electronic issues. Will contact dealer if I don't have next weekend.
awning, light
