Old 03-22-2016, 07:21 PM   #11
Thanks I called the dealer and asked where the receiver was and they didn't know ....so I guess I will have to take it in ....
Jingletv is offline   Reply With Quote
Old 03-23-2016, 12:49 PM   #12
jgump's Avatar
Originally Posted by Jingletv View Post
We just picked up our wildwood and the awning lights won't turn on.... With the remote or the inside switch.... Also the stabilizers won't work with the outside switches....any help?
Thanks!
Vicki
Vicki - we have a wildwood 27rkss. The led light strip under the awning is controlled by the inside rocker switch or the multicolor remote. IF you turn off the lights with the remote, on mine, the inside switch is useless. The receiver for the remote for the lights is a small white plastic piece sticking out from where the wiring of the led strip goes into the side of the trailer. You'll have to aim the remote in that direction. Hit the power button on the remote. See if this helps. Try with inside switch in the on position and off position.
As to the power stabs, that could be a fuse issue or bad switches. If so, take it back to dealer.
By the way which wildwood do you have?
John
2016 Wildwood 27RKSS
2012 Grand Cherokee Overland (Hemi)
jgump is offline   Reply With Quote
Old 03-23-2016, 02:16 PM   #13
Yay!!!! Thanks! We tried it and the lights work! We have the 273QBXL....
Thank you so much!
Old 03-23-2016, 02:34 PM   #14
jgump's Avatar
Thank you so much!
Very welcome. Glad I could help!
Old 05-09-2016, 04:14 PM   #15
I too have the same issue with the front stabilizers. The switch worked when we setup and when time to go home it didn't. The remote still works which tells me that everything mechanically is okay. I checked the fuse panel and fuses are good. All I can think of is the switch went bad or there is an inline fuse somewhere. Of course all of the wiring is all taped and haven't wanted to tackle it yet. Have you gotten any more feedback on yours?
tnovak is offline   Reply With Quote
Old 05-22-2016, 03:36 PM   #16
Mine quit working and the trailer is only 2 months old. Is there a fuse behind the control panel by the door?
Joe5988 is offline   Reply With Quote
awning, light
