Old 03-21-2016, 08:06 PM   #1
Awning Lights Help
We just picked up our wildwood and the awning lights won't turn on.... With the remote or the inside switch.... Also the stabilizers won't work with the outside switches....any help?
Thanks!
Vicki
Jingletv is offline   Reply With Quote
Old 03-21-2016, 08:23 PM   #2
Congrats on the new trailer! Sorry to hear about your problems. If it is a new trailer, I would take it back to the dealer and let them deal with it. As much as they cost, everything should work. If could just be a fuse with the stabilizers. Check the simple things first such as fuses, wire connections, etc.
2015 Cherokee 274DBH
2015 Ram 3500
klrobert is offline   Reply With Quote
Old 03-21-2016, 10:15 PM   #3
Thanks! We may have to but I wanted to see if it was just something simple first.... The dealer is an hour and half away....
Old 03-22-2016, 09:53 AM   #4
Did they work at the dealer when you did your PDI?
Eastlake, Ohio
2013 F-350 Turbo Diesel
2016 Heritage Glen 368rlbh
Dinostop is offline   Reply With Quote
Old 03-22-2016, 09:59 AM   #5
Yes they worked at the dealer...
Old 03-22-2016, 10:22 AM   #6
Brother Les's Avatar
Check the simple things before you take it back to the Dealer, if they worked before, it should be a simple thing. If you take it back to the Dealer it may be weeks before you get it back and camping season it coming up and they may be very busy. Look things over and double check and get back to us. Get to know your unit. if all else does not work and you can not find it, it is under warranty. Ask the Dealer for a date to take it back when they can get on it quickly so it is not sitting on their lot for a couple of weeks or longer, but get your name 'inline' for warranty work. Call the Dealer and they may have a good suggestion.
Brother Les
Old 03-22-2016, 10:42 AM   #7
Thanks I have a call into them now.... Waiting to hear back.
Old 03-22-2016, 11:20 AM   #8
You mentioned you had a remote with it. Have you checked your main fuse panel as well as the fuses on the remote control panel? Does your remote control the jacks as well as the awning lights? What kind of remote system do you have?
Eastlake, Ohio
Old 03-22-2016, 03:03 PM   #9
The stabilizers work with their remote..... The awning lights are on different remote
RGBW controller
Old 03-22-2016, 06:08 PM   #10
Definitely sounds like a fuse issue to me. I know in some of the remote systems there is are fuses on the control panel for the remotes I would check there as well as the main fuse panel.
Eastlake, Ohio
awning, light
