Old 08-23-2015, 09:52 PM   #1
axle hub size
We have a 2004 flagstaff 176 SD ltd and getting ready to 5000 miles on it starting this Thursday
I want to a extra wheel hub for it just in case it goes bad on our trip
Could someone tell the size I could get to have a spare with me
W. Brett Rhodes
rocknrubi04 is offline   Reply With Quote
Old 08-24-2015, 09:04 PM   #2
axle hub size
Cam Anybody help me
Old 08-24-2015, 09:23 PM   #3
TURBS's Avatar
Likely without taking it off and getting the bearing sizes, bolt pattern and seal number we'd only be guessing.
Once you have that got to e-trailer.com
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-25-2015, 01:44 AM   #4
arpipeliner's Avatar
Can crawl under the camper and look for tag on the axle. Usually on back side and towards the right. Might be able to get the info by checking with the manufacturer or etrailer. I did that but still tore into a hub to make sure before ordering my parts.
arpipeliner is offline   Reply With Quote
Old 08-25-2015, 02:04 AM   #5
Just a member
kandl's Avatar
RVers are known for carrying lots of extra stuff when they hit the trail but an "extra wheel hub" is probably pushing the envelope. Are the wheel hubs on this particular trailer prone to failure?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 08-25-2015, 04:33 AM   #6
I could see it if I was going in very remote locations. But I would just pull them apart and repack bearing and place the seal and have the piece of mind. OP might have had a bad experience or knew someone that did and cover his bases.
Old 08-25-2015, 05:19 AM   #7
Crockett's Avatar
when was the last bearing pack? id check sizes when performed if I were going that distance. bearings are most likely 44649 and 68149. 5 on 4.5. an idler hub could get you through an emergency. just a hub with no drum. smaller than a cereal bowl and fairly cheap.
Crockett is offline   Reply With Quote
Old 08-25-2015, 09:01 AM   #8
Thanks for the info guys
axle
