Old 08-27-2007, 08:05 PM   #1
axle problems
I know this is from another manufacturer, but I think most of the axles are from Lippert. Check out this thread from Crossroads RV - http://www.crossroadsrv.com/forum/to...?TOPIC_ID=3781
This happened to my longtime friend on his way back from the Bristol race and he is totally confused as to why. Just wanted to give everyone a heads up to add this to there list of things to check.
Check out the pictures I think I attached
ID:	351   Click image for larger version
ID:	352   Click image for larger version
ID:	353   Click image for larger version
2003 F-250 5.4 manual gearbox w/ 4.10's
2007 Puma 29RKSS
kilowattkid is offline   Reply With Quote
Old 08-27-2007, 09:53 PM   #2
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Another great reminder to crawl around and keep checking your equipment.
Thanks for sharing.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 08-28-2007, 07:02 AM   #3
Thanks for sharing.
Yep.
aintgotnun is offline   Reply With Quote
Old 08-28-2007, 06:04 PM   #4
Biker trash
fxstsharleyrider's Avatar
Wow I thought I had the axle blues. What caused it? Tim
2006 32 SRV Forest River toy hauler.
2007 Chevy Duramax LT.
1989 Harley FXSTS.
Garage full of RC planes
Bella female Boston, Nick male Great Dane Boxer mix.
two girls all grown up.
Wife of 26 years, without her all of the above would be just a dream.
fxstsharleyrider is offline   Reply With Quote
Old 08-28-2007, 06:09 PM   #5
milzat's Avatar
Look like it's been torqued in the rotation of travel. It's possible this is caused from the TT brakes being applied with great force.
My TT doesn't have leaf springs, but has rubber torsion suspension. The photo below shows something similar happening to my TT.
Notice how the axle moved in the rotation of travel.
I believe this happened as a result of a sudden, hard braking situation. This is the only explanation I can come up with at this time.
Read my post on this HERE
milzat is offline   Reply With Quote
Old 08-28-2007, 06:38 PM   #6
Biker trash
I'm not all that smart. but one thing I try not to do is hit the brakes to hard while going over large bumps or pot holes. I don't know if it would cause this or not but I'm sure it dosn't help.
1989 Harley FXSTS.
Old 08-29-2007, 10:22 AM   #7
The pictures shown are after he rotated the axle back 180 degrees. So at one point it looked much worse that this. I would like to think that once the u-bolts are torqued down, you would never have to check them again. I also would think that you should be able to lock the brakes up and drag it down to the rims with out this happening. You aren't required to routinely check the leaf springs on you tow vehicle are you?
I'm just glad evryone was O.K. and that they are getting it fixed ASAP by dealer. Sure seems that it could have been a lot worse.
2007 Puma 29RKSS
Old 08-29-2007, 10:37 AM   #8
RAC
I thought it looked as if the ubolts did slip around. They looked like they were fairly cheesy as far as what they were cast in. To me it looks like they stripped the threads on one side as they are torqued uneven. Perhaps a case hardened upgrade would be a permanent solution?
RAC is offline   Reply With Quote
axle
