This is just 5 pic and I have alot more. This celebration go's on evey year, It is something to see. If you and your family get a chance to spend a vacation at Pirateland, I think you will enjoy it.
How as far as mods go!
TIRES: My 8314ss came with ST205/75R15-C rated Carlisle, I changed them out and installed ST225/75R15-D rated Goodyear Marathon's and had them balanced as recommended by many FRF members, What a difference, Vibration from the TT was reduced or just about eliminated due to tire balancing, this made a smooth towing experience. Now C rated tires are 6 ply and D rated tires are 8 ply, with 8 ply tires as the big rig rolled by sway was reduced and had no problem with contol, I wish I made these change earlier.
HEAT LOAD: My 8314ss came with a Domstic A/C system 13,500 BTU, I suffered with this unit two years ago at the same camp ground. Prior to our trip I had a Carrier A/C system installed, but bigger 15,000 BTU. This unit worked great. My wife made curtains for the windows and I installed the with spring rods. They were made to help keep the heat out along with the day/night shades and sealed of the two sky lights. The other thing I did was set the fan to the A/C unit to ON so it would keep the air circulating and keep a balanced temp so there was no hot spots..... MORE LATER, 2:30 am comes early for the first day back to work after two weeks off....
