No. Well....not completely anyway. You wouldn't be able to use the existing mounting kit from the looks of it. Even if it fits in the space, the Furion unit has the antenna on the side and it looks like that unit is dead center. Wiring it up would be easy enough. The Furion unit just uses a headphone jack type of connector. At worst, you just cut off the connectors and splice away. If I were going to attempt it, I'd remove the factory kit from the trailer and install the new one in the same spot then splice the power wires and make sure everything is sealed really well.
