Old 04-17-2014, 08:45 AM   #11
TURBS's Avatar
Originally Posted by simplyrwc View Post
Or turn on the hot water spigot until all the air has purged.
Don't do this.
Its possible that your wh heater is still bypassed which gives you a false sense of the tank being full when in fact its empty!
When wh is by passed you'll still get water out of the hot tap.
Sorry lou beat me.
TURBS
Sabre owners united!
Old 04-17-2014, 09:15 AM   #12
simplyrwc's Avatar
Originally Posted by f1100turbo View Post
Don't do this.
Sorry lou beat me.
TURBS
Sorry didn't mean to pass on bad info but glad it was corrected!
My trailer doesn't have a bypass, unless I am more ignorant than I thought?
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
simplyrwc is offline   Reply With Quote
Old 04-17-2014, 11:12 AM   #13
We don't turn on our water heater until about 30 minutes before we require hot water and we turn it off when we are done using hot water. We don't leave it on all of the time.
whj77372 is offline   Reply With Quote
Old 04-17-2014, 08:51 PM   #14
OK another stupid question. Where would a bypass valve be? I flushed the system last weekend and sanitized it, did not know about bypass.
NorthernVandal is offline   Reply With Quote
Old 04-17-2014, 09:15 PM   #15
Toby's Avatar
Mine has 3 ball type valves on the inside of the trailer. I have to open an access panel to get to it.
Also before you use your propane fridge/hwh, make sure you run the stove to get the air out of the lines. Otherwise you'll have to reset everything.
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
Old 04-17-2014, 10:41 PM   #16
Herk7769's Avatar
How they plumbed your water heater is model dependent. They all should have bypass valves or when you winterize you will use an additional 6 to 10 gallons of RV anti-freeze to fill the HW heater.
There is a one valve type that uses a "T" type valve and a check valve in the hot water out port in the water heater, and a 3 valve system that uses no check valves. There have been reports of a 2 valve setup with a check valve but I do not have a photo of that type.
ALWAYS make sure the AC power switch is OFF (shown with a safety pin through it) before draining the water heater. Not all water heaters have an AC power option.
ID:	50108   Click image for larger version
ID:	50109   Click image for larger version
Name:	Rocker Switch.jpg
ID:	50110   Click image for larger version
ID:	50111   Click image for larger version
Name:	Water Heater Outside.jpg
ID:	50113   Click image for larger version
ID:	50114   Click image for larger version
Name:	Sunseeker single valve system.jpg
ID:	50115   Click image for larger version
HAM CALLSIGN - KC3FFW
first time
