Old 03-15-2015, 07:23 PM   #1
mlwilliams808's Avatar
Basic RV 101 questions
I am a first time TT owner and I have some very basic questions.
* When TT is set up is it best to leave water heater on or use it when needed?
* Water Heater best powered by gas or elect when set up?
* When towing is it better to use the inverter to power refrig or gas?
We are taking a 3 day shakedown trip that's about 5 miles from dealer, then at the end of the month the learning curve steepens with a trip from Louisiana to California.
Thanks in advance for your advice.
Legacy 38C SR-340
mlwilliams808 is offline   Reply With Quote
Old 03-15-2015, 07:30 PM   #2
Crusadernoob's Avatar
We always leave the heater on
Use electric, you are already paying for it with the site.
Gas
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 03-15-2015, 07:31 PM   #3
vinmaker's Avatar
As you will be wanting hot water on demand, it is best to keep it on. The gas feature will heat up your water faster but this cost you propane. You already pay for electric, so that is essentially free but it will heat up slower.
I like to tow using the gas feature on the fridge because it works better on propane than electric DC current.
Hope this helps and hope you have a great time in your new rig.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 03-15-2015, 07:33 PM   #4
bigdaddy1
bigdaddy1's Avatar
I leave the hot water heater on elect...but we I first set up I usually turn on gas first just to get a cycle on it. Make sure you have water going through hot water heater. If you leave camper for sight seeing etc turn off water source and hwh too. Frig is another thing that is often disagree upon so I will not comment on it..just research it.
BigDaddy1
2015 F350 CC Lariat 4/4 SRW
6.7 diesel
2016 3850RL Cardinal
bigdaddy1 is offline   Reply With Quote
Old 03-15-2015, 07:40 PM   #5
you want to leave the water heater on while using the trailer. you can actually use both gas and electric for unlimited hot water, good if you have kids and you all shower.gas costs you more money if you have power hook up at the site use electricity. my fridge will switch to gas from electric as soon as i pull the plug at home and head out. i have never had a problem running the fridge on gas when traveling. some people say you need to turn the pilot light off while fueling at the gas station but i never do and feel it is not needed. you will get different thoughts on this. good luck and have a great trip. one word of advice, do NOT turn on the water heater with the water tank empty. it will burn up the element in seconds. make sure the tank has water in it before turning it on.
enjoy!
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
Old 03-15-2015, 07:45 PM   #6
wbdavey's Avatar
For the water heater, use electric when ever you can, but always turn it off when you travel. That way you don't instantly turn on the heater when you plug in at the next campground before you've got the water hooked up and the water heater full. You can use propane on the refrigerator when traveling. Some will caution you to turn the gas off if you stop to fuel up you tow vehicle. I never have, and so far I've not blown myself up.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 03-15-2015, 07:51 PM   #7
Blackhat6mike's Avatar
Do you mean "CONVERTER"[110vac to 12vdc] rather than "INVERTER"[12vdc to 110vac]? Did your unit come with an inverter?
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-15-2015, 09:11 PM   #8
I have an inverter installed as OEM, Thanks for the advice
Legacy 38C SR-340
Old 03-15-2015, 09:13 PM   #9
Thanks, I guess it would be a good idea to hook the water up first?
Legacy 38C SR-340
Old 03-15-2015, 09:38 PM   #10
Platokidd's Avatar
When Im set up at camp I have the hw on electric. When we shower I turn the gas on and then off when done.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
