Old 01-11-2017, 08:22 PM   #21
Newly Retired
Steveboe's Avatar
I did not bother drilling holes when I noticed mine was full of water. It took a long heavy duty screwdriver and punched it through the bottom of the box with a hammer. Problem solved. Didn't have to remove the battery Or disconnect it.
Steveboe is offline   Reply With Quote
Old 01-11-2017, 08:32 PM   #22
OK, so you`re a puncher not a driller, lol.
2017 Coachmen Catalina 283RKS
2004 Chevy Silverado 2500HD Crew Cab
Crabman is offline   Reply With Quote
Old 01-11-2017, 08:55 PM   #23
He's a "Tool Push" not a "Driller".
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is online now   Reply With Quote
Old 01-11-2017, 09:16 PM   #24
Another vote for drilling holes in the bottom. "NO MORE RAIN IN MY BOXES"!
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 01-11-2017, 09:43 PM   #25
donNjudy's Avatar
What about this? Lots of cars have batteries under the seat. I have a 67 VW battery under back seat. Corvettes, buick, lots of gm's are vented but no box. Batteries usually DO NOT Leak. I was a mechanic and shop owner 50 years plus. Don
donNjudy is offline   Reply With Quote
Old 01-11-2017, 11:00 PM   #26
Most new trailers have vents to get rid of hydrogen gas also. Very explosive. Had to modify my boxes when I converted to golf cart batteries. Drilled holes to drain water.
Comanchecreek is offline   Reply With Quote
Old 01-11-2017, 11:30 PM   #27
I guess one could go to Wal-mart and find a clear plastic storage bin that would fit nicely up-side down over the battery box(s) and use a bungy cord to hold it down. Just sayin...
Bruce, Kansas
2016 Grey Wolf 26RR...100 nights camping since new
2006 Deluxe Harley Davidson
1993 Kawasaki KLR 650
1998 Polaris Sportsman 500 ATV
2004 f150 & 2008 f350 dually V-10
hiinthesky is offline   Reply With Quote
Old 01-12-2017, 02:31 AM   #28
Actually...I not only drilled drainage holes in the bottom of the boxes I used silicone to seal up to top vents to prevent water from coming in. There is PLENTY of ventilation where the cables come out and from the holes in the bottom. Problem completely solved. Been doing this for at least 40 years.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 01-12-2017, 04:50 AM   #29
Doesn't matter if you drill the box or punch the box, it's usually good for the box.
Mr Havercamp is offline   Reply With Quote
Old 01-12-2017, 05:30 AM   #30
bareftn's Avatar
Originally Posted by timfromma View Post
The boxes are made to contain any acid that may leak from the battery. Drilling holes defeats the purpose of using a battery box in the first place doesn't it?
When was the last time you saw a battery leaking? just about all batteries are a sealed type. Does a car or truck have a battery box? The batter box is to keep the battery covered and the post from from weather and the battery from resting on the frame and looks better covered . Just drill a hole or 2 and don't worry about it ,
bareftn is offline   Reply With Quote
Old 01-12-2017, 09:12 AM   #31
Drill it!
D-Man is offline   Reply With Quote
Old 01-12-2017, 09:32 AM   #32
f5moab's Avatar
About two years ago, but not leaking from the case; from the caps.
Many of the deep cycle batteries are still wet so not sealed.
Mine leaked from the caps due to the roads (or should I say trails) traveled with the trailer. (One reason why I travel with a jug of distilled water to add to the batteries, if needed, in the truck bed.)
Won't happen to 99% of the people, but it can happen if you travel really nasty trails. And can happen to those pulling off-road type trailers on really nasty, but fun, trails.
f5moab is offline   Reply With Quote
battery, water
