Old 08-13-2019, 07:17 PM   #1
RangeMaggotBob's Avatar
Battery Change-out
I've been thinking about changing out to 6 volt batteries. What group size do I want/need for my size RV? I currently have just one 12 volt. Thanks for any info.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
RangeMaggotBob is offline   Reply With Quote
Old 08-13-2019, 08:09 PM   #2
Hi Mr Zappa
The size you want is GC2, depending on the make they will range from about 210ah to 240ah.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is online now   Reply With Quote
Old 08-13-2019, 08:36 PM   #3
I recently changed out my 12v for two GC2s from Sam's Club. These are larger batteries of course and 2 of them just fit into the battery space of my 21ds. The benefit of this setup is that you can boondock for a lot longer than with the standard 12v battery. The cost wasn't too bad either!
2007 Dodge Ram 1500 Hemi
2017 Flagstaff 21ds
WTP2 is offline   Reply With Quote
Old 08-13-2019, 08:42 PM   #4
SlowrideHD's Avatar
It's hard to beat the proven performance of Trojan T-105 6 volt batteries. They weigh 62 lbs each. You can get a similar battery at Costco for a few bucks less, but it still isn't a Trojan. I buy mine from a local golf cart shop for about $110 each. Well worth the money.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
SlowrideHD is offline   Reply With Quote
Old 08-13-2019, 09:15 PM   #5
Keep in mind you’ll need an additional wire to go from the positive to the negative posts to connect the two 6V in series.
AvidFlyer is offline   Reply With Quote
Old 08-13-2019, 09:34 PM   #6
bikendan's Avatar
The GC2 6v golf cart batteries have the same footprint as the Group 24 12v batteries. They are just taller.
Old 08-13-2019, 09:42 PM   #7
Originally Posted by boondocking View Post
Hi Mr Zappa
Thank you so much! And everybody else, too.
Old 08-13-2019, 11:32 PM   #8
You're Welcome!
2007 Surveyor SV230
Old 08-14-2019, 04:44 AM   #9
The Costco GC2 6V Golf Cart batteries are $98
Features:
  • Costco Item Number: 850284
  • GC2 Group Size, 6 Volt
  • Not Available for Purchase Online
  • May Be Available at Your Local Costco Warehouse
ATTENTION: Due to HAZMAT compliance requirements, shipping is not available for Golf Cart batteries at this time. Please visit your local Costco Wholesale Club to purchase the battery that’s right for you.
IMPORTANT NOTE: Refundable core charge of $15.00 not included in pricing.
Golf Cart Batteries - Unlike automotive batteries, golf cart batteries don't need starting ability. Instead, they need to be able to power your cart with long periods of time between charges. In most warehouses, we have batteries for both 6-volt and 8-volt systems.
Specifications:
  • Group Size: GC2
  • Part Number: 9-GC2-UTL
  • Voltage: 6
  • Reserve Capacity(RC) @ 25Amps: 105
  • Reserve Capacity(RC) @ 75Amps: 175
  • Amp Hours(Ah) @ 20Hr: 210
  • Amp Hours(Ah) @ 5Hr: 175
  • Length: 10 5/16"
  • Width: 7 1/8"
  • Height: 11"
  • Weight: 58lbs
https://www.costco.com/Interstate-6-...100476406.html
2019 Ram Bighorn, CC/SB 2500 4x4 6.4L/8 Speed, Max Tow 14,460 lb/2,940 lb payload.
2019 F-150 King Ranch 3.5 Eco, 12,800 lb/1,546 payload.
2020 Coachmen Apex UL 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 IronBull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
battery
