10-22-2014, 02:07 PM
Battery charging
Have Rockwood 2109S, does the battery get charged from the tow vehicle when traveling, also when we stop overnight and do not unhook trailer should we unplug trailer wire connection to eliminate draining tow vehicle battery?
10-22-2014, 02:25 PM
Please post what vehicle you have and year......
Fonzie
10-22-2014, 02:26 PM
Depending on your tv and if it's been enabled.
Turbs
10-22-2014, 02:32 PM
Dazed & Confused
On my Tundra and the F150 I had prior, 12 vdc is available at the 7 pin plug only when the vehicle is running. On both it is switched through a relay, so in that case, no it would not drain the vehicle battery if left plugged in.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
10-22-2014, 02:35 PM
My truck a F350 charges my battery when in tow. When truck is off no.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
10-22-2014, 02:40 PM
'Depends' on your tow set up. What does your vehicle manual say? To check, take a volt meter to your 7-pin connection. Check from the 'hot' (charge) wire to a ground with the truck OFF. Is there voltage (12.5v)? If you Do Not....Good. If you do, then you have a continues hot wire and can run down your batt if left hooked up over night. Now, if there is no voltage, start the truck and see if there is voltage...? If 'yes', then you are charging your units battery... If no, then you need to find out why no voltage???? No fuse? Wire not attached? so on, so on.
Brother Les
10-22-2014, 04:28 PM
Have a 2010 GMC Sierra Ext Cab for tow vehicle
10-22-2014, 05:17 PM
GM is kind of iffy about things like that. They'll do something one way one year then switch the next year then back again the year after so it's hard to say. Most models, the battery run down protection will kill everything after so long at any rate (or should, anyway).
I've got the same model, different floor plan of your trailer and I can say that it WILL NOT charge if the disconnect is thrown, so if it's a concern, you don't need to unplug, just disconnect with the switch. UNLESS you need the 12V for something like the refrigerator control...then leave the battery switch alone and unplug from the truck.
10-22-2014, 05:32 PM
Battery charging
Thanks all, I think I will take Brother Les's advice and get a test light to check the plug as he said. It was good solid advice.
10-22-2014, 07:51 PM
This may help
http://www.countrytrailer.com/uploads/7wayplug.pdf
This diagram will probably help but you should see voltage on the one that has the black wire to it (right alongside the tab in the plug) On my F-150 I had to install a relay and fuse under the hood but don't know if your truck will need that.
Other Motorhome
2013 F-150 Eco-Boost V6
