Old 09-20-2016, 12:37 PM   #1
Battery Disconnect - Parasitic drain on batteries
I have a new Heritage Glen 368. Every time I leave the trailer in storage I make sure that all lights, inverter etc all all turned off. When I get back in about a week, the batteries are all run down.
I put 2 new batteries from a local distributor into the trailer shortly after picking it up, because I wanted to ensure I got the freshest ones possible and not ones that had been siting at Forest River for a year.
Looking at other posts, other trailers have disconnects, mine does not seem to have one. Attached is a picture of my electrical block above the primary battery box
Any thoughts on a mod?
Jeff from Burlington Ont is offline   Reply With Quote
Old 09-20-2016, 12:42 PM   #2
No photo displayed. You should not have trouble adding one
2016 Flagstaff 23lb
Toddupton is online now   Reply With Quote
Old 09-20-2016, 12:51 PM   #3
Easy to do, you can also just disconnect the negative to ground lead for now.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 09-20-2016, 01:05 PM   #4
Fulltime family RVer
I opted for a cheap one from eBay. My father-in-law helped me install it (so that it was neat and pretty). But, this was definitely one of those "so simple that even I could do it" kind of installs.
Dead Battery in Storage – Installed a Battery Disconnect | Learn To RV
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 09-20-2016, 02:47 PM   #5
I too installed a battery disconnect. Got mine from Princess Auto which, as near as I can tell, is the Canadian version of Harbor Freight (although we would spell it "Harbour").
More details and photos in the full write up at Mods - Battery switch
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
illegitimi non carborundum
Restcure is online now   Reply With Quote
Old 09-20-2016, 03:08 PM   #6
Moderators' Assistant
bikendan's Avatar
Jeff, many brands of trailers don't have factory disconnect switches.
All RVS have parasitic power drains, newer ones even more.
Also, Forest River doesn't install the batteries, the dealer does.
The best disconnect switches are the marine type.
But you can also buy cheaper ones that cost around $6.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 09-20-2016, 03:18 PM   #7
Sorry.. here was the picture of my compartment
Old 09-20-2016, 03:39 PM   #8
Learning a lot as I go...
Could also use a high amperage master circuit breaker to cut power (if you place in the right spot). On my Rockwood I happen to have a factory cutoff switch and *now* a master circuit breaker. I found reason to use the breaker the other day when I wanted to remove the breakaway plug to repair the cable (the breakaway switch wires into the battery directly and is not switchable by the cutoff switch).
2015 Rockwood 2604WS (sold as 2016)
2014 Ford F-150 Ecoboost
stevejahr is offline   Reply With Quote
Old 09-20-2016, 04:40 PM   #9
Get yourself one of these and splice it into the negative battery cable. This what I use and it works like a charm.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 09-21-2016, 01:12 PM   #10
Casino Camper
jughrad's Avatar
Probably not the very best solution but this video shows where my parasitic draw was coming from and how I installed my battery cutoff switch. At the time I was mostly concerned about not drilling into my brand new trailer so I put it on the $7 battery box. Just another idea for your decision making.
2016 Cherokee 264L
2013 GMC Sierra Denali
EAZ Lift 1000 WDH w/Sway Control
2016 Nights Camped: 24 Trips: 8
jughrad is offline   Reply With Quote
battery, battery disconnect, drain
