Old 09-07-2015, 08:11 PM   #1
Battery from Tent Trailer - what is this corroded part on top?
Our tent trailer has been sitting for a year and we went to get it ready for a trip - and the battery has some corrosion happening on the top of it. What is that piece on top that is corroding - the one with the 4 nuts on it? I'm not sure what it is, what it does or if I just need it for connecting those extra cables? Thanks in advance for any help!
yyccarla is offline   Reply With Quote
Old 09-07-2015, 08:38 PM   #2
I'm guessing it's a disconnect switch, but it's hard to tell. Not sure why there would be 4 nuts on it. At first I thought it went from one battery post to the other, but then I realized the red wire at the top just passes under the black wire.
It could also be part of a current sensing circuit. The extra two connections would go to an ampere meter of some sort.
2011 Traverse LT, 3.6L, FWD
Old 09-07-2015, 08:42 PM   #3
Done with this
I'd definitely get rid of it, whatever it is...
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 09-07-2015, 09:04 PM   #4
here are a couple closeups of the mystery attachment - my husband is researching on the internet and is having trouble finding any info. It came from the factory new like this to us ( or something dealer did maybe... ).
Name:	battery attach closeup.jpg
ID:	88086   Click image for larger version
Name:	battery attach close up 2.jpg
Old 09-07-2015, 09:18 PM   #5
Jimandchris's Avatar
Looks like a couple of paralleled circuit breakers, like a Short Stop 12vdc
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
Jimandchris is offline   Reply With Quote
Old 09-07-2015, 09:20 PM   #6
Dsfast's Avatar
The pictures are of some circuit breakers you can get new ones at most automotive parts stores.You should replace them if they are factory because they will protect something electrical in the trailer like a fuse would.
Dsfast is offline   Reply With Quote
Old 09-07-2015, 09:22 PM   #7
If there's a small button on the side, they're definitely circuit breakers.
Old 09-07-2015, 10:13 PM   #8
Wow - the folks on this forum are quick. Thank you for all the replies - we now have a better base to finish our research! Need to get it sorted out before next weekend!
Old 09-07-2015, 10:51 PM   #9
Blackrock's Avatar
These are what you need and if I remember correctly this circuit is for your power winch that raises the roof on your popup. You can neutralize the acid corrosion with a mixture of water and baking soda. Warm water works best flushed with plenty of water afterwards.
The original circuit breakers may still have the amperage rating printed on them but my guess is they are 20 amp if they are set up as a pair.
Auto Reset Automotive Circuit Breakers - Metal with Bracket
Available at most any auto parts store.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 09-07-2015, 11:30 PM   #10
Bluepill's Avatar
FYI - If the battery was not on a maintainer or regularly charged during the year of non-use, it will be useless.
Old 09-08-2015, 12:06 AM   #11
Just a member
kandl's Avatar
Originally Posted by yyccarla View Post
Our tent trailer has been sitting for a year and we went to get it ready for a trip...
Fully charge and disconnect the battery when long-term storage is in the trailer's future. Anything more than a few or four weeks unless you're routinely charging it. Better yet, remove the battery and store it in a cool, dry location.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
Old 09-08-2015, 12:46 PM   #12
rsdata's Avatar
pop off the caps on the top of battery and fill with distilled water if the level is not up to the bottom of the internal ring... then recharge the battery
while at auto parts store get a spray can of stuff to spray on battery terminals to prevent this next time
2014 Shamrock 183
Old 09-08-2015, 04:49 PM   #13
They are circuit breakers or relays (need to pull one apart to be sure) either way you can get them at most any auto parts dealer. Either way they should be replaced as they will help or protect your electric system in your pop-up from issues in future. After you replace them keep the area clean and coat them with a good battery protector spray this will help in the future with the corrosion issues.
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 09-08-2015, 06:41 PM   #14
Believe it is the same thing I had on boat battery if so it is a fusible link that susposed to burn out if overcharging. As for the corridor mix up some baking soda and water it will clean the outside of the terminals and connections. You can buy a pad that fits over the post and it will the corosin from forming. Any auto parts store has them they also carry them at Wal-Mart.
Myrle is offline   Reply With Quote
battery, tent trailer, trailer
