Old 09-07-2015, 08:11 PM   #1
Battery from Tent Trailer - what is this corroded part on top?
Our tent trailer has been sitting for a year and we went to get it ready for a trip - and the battery has some corrosion happening on the top of it. What is that piece on top that is corroding - the one with the 4 nuts on it? I'm not sure what it is, what it does or if I just need it for connecting those extra cables? Thanks in advance for any help!
yyccarla is offline   Reply With Quote
Old 09-07-2015, 08:38 PM   #2
I'm guessing it's a disconnect switch, but it's hard to tell. Not sure why there would be 4 nuts on it. At first I thought it went from one battery post to the other, but then I realized the red wire at the top just passes under the black wire.
It could also be part of a current sensing circuit. The extra two connections would go to an ampere meter of some sort.
2011 Traverse LT, 3.6L, FWD
Old 09-07-2015, 08:42 PM   #3
Done with this
I'd definitely get rid of it, whatever it is...
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 09-07-2015, 09:04 PM   #4
here are a couple closeups of the mystery attachment - my husband is researching on the internet and is having trouble finding any info. It came from the factory new like this to us ( or something dealer did maybe... ).
Name:	battery attach closeup.jpg
ID:	88086   Click image for larger version
Name:	battery attach close up 2.jpg
Old 09-07-2015, 09:18 PM   #5
Jimandchris's Avatar
Looks like a couple of paralleled circuit breakers, like a Short Stop 12vdc
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 09-07-2015, 09:20 PM   #6
Dsfast's Avatar
The pictures are of some circuit breakers you can get new ones at most automotive parts stores.You should replace them if they are factory because they will protect something electrical in the trailer like a fuse would.
Dsfast is offline   Reply With Quote
Old 09-07-2015, 09:22 PM   #7
If there's a small button on the side, they're definitely circuit breakers.
Old 09-07-2015, 10:13 PM   #8
Wow - the folks on this forum are quick. Thank you for all the replies - we now have a better base to finish our research! Need to get it sorted out before next weekend!
Old 09-07-2015, 10:51 PM   #9
Blackrock's Avatar
These are what you need and if I remember correctly this circuit is for your power winch that raises the roof on your popup. You can neutralize the acid corrosion with a mixture of water and baking soda. Warm water works best flushed with plenty of water afterwards.
The original circuit breakers may still have the amperage rating printed on them but my guess is they are 20 amp if they are set up as a pair.
Auto Reset Automotive Circuit Breakers - Metal with Bracket
Available at most any auto parts store.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 09-07-2015, 11:30 PM   #10
Bluepill's Avatar
FYI - If the battery was not on a maintainer or regularly charged during the year of non-use, it will be useless.
2008 Itasca Meridian 37H
Bluepill is online now   Reply With Quote
battery, tent trailer, trailer
