Old 11-04-2010, 07:44 AM   #1
Best and Easiest way to get RV anti Freeze in lines
I have a new 2702 SS on its way. I plan to take it to branson of Thanksgiving, I already plan to remove the heater plug/anoid, blow out water lines including outside shower, open low water points, of coarse poor anti freeze in traps and toliet, but???????????
how is the best way to get the antifreeze in the lines?
I know turn the WH by pass on.... but from that point wat do I need to do?
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 11-04-2010, 07:51 AM   #2
MtnGuy's Avatar
Most campers have a dedicated antifreeze suction line at the water pump inlet. There is a 3 way valve that allows you suction the water directly out of the antifreeze bottle through the pump and into the lines. On the PDI, have the dealer show you where that is.
Old 11-04-2010, 09:08 AM   #3
I had trouble with the dedicated suction hose on mine last year, so I removed the inlet hose at the pump, inserted a rubber hose, and drew the antifreeze directly from the bottle.
Just a note...I took delivery of an RV in late October once, and it had already been winterized. I don't know where you live, but you may want to check with the dealer to see if they have already done it.
grandpaofthree is offline   Reply With Quote
Old 11-04-2010, 03:49 PM   #4
Dan the Busman
Busman1947's Avatar
Dan the Busman
The best thing I can tell you to do is go to RVbasics.Com RV Basics .com - RV Information for RVers about RVing and the site will tell you everything you would ever want to do to or with an RV. That's the advice I was given and it wwas well worth the trip to the site.
Good LucK
Dan Lipinski
2008 Flagstaff 27BHSS
2005 Nissan Titan
Busman1947 is offline   Reply With Quote
Old 11-05-2010, 02:02 AM   #5
also make sure your hose isnt too long i had trouble getting mine to pump the first time i did it then i shortened the hose and no trouble since
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
