Old 01-23-2013, 02:31 PM   #11
A Roto-Zip with guide and a fine metal cutting tip. Use masking tape to reduce splintering and act as a guide.
mwebber78 is offline   Reply With Quote
Old 01-23-2013, 02:42 PM   #12
caper's Avatar
If using a circular saw put the blade in backwards. The teeth will not bite into the siding and cause it to rip. A dremel tool to cut the siding the you could us a jig saw to cut the rest of the opening.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-23-2013, 02:49 PM   #13
Denver, CO
garbonz's Avatar
Oscillating saw.
My son is a contractor and uses it for everything. Very controllable and precise.
Old 01-23-2013, 03:03 PM   #14
Crusader's Avatar
Its a oscillating saw ...............a tool of many uses..........
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 01-23-2013, 06:53 PM   #15
cantho's Avatar
Hand nibbler works great patching UH1H aircraft.
cantho is offline   Reply With Quote
Old 01-23-2013, 07:06 PM   #16
wfmdfm's Avatar
I have one of these and use it for many projects. I love it and I have all the saws, grinders,roto zip, hole saw. This would be my choice without a second thought. Good luck and post some pictures.
Wally
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 01-23-2013, 07:20 PM   #17
Oklahoma Proud
MillerTime's Avatar
I would either just use the cuttoff wheel( that's what I use a work most of the time) and usually the paint wont curl more than just about 1/32 if that on steel(car bodys) . Or use a hole saw and take my oscilating saw and make the corners. .....honestly I think I would just use my 3" cuttoff wheel and be done 30 seconds ago. Use masking tape to mark the edges- also helps if the blade skips.
- ps. I Work in a body shop- so I have cut couple pieces of metal before
Old 01-24-2013, 07:30 AM   #18
Wally
Are the pictures for a good laugh if I screw up the side of my camper???
Old 01-24-2013, 09:23 PM   #19
VinceU's Avatar
Use a stud finder or other means to locate and mark the internal alum or steel square tube stiffeners. Lay out your hole accordingly if you are cutting blind into the wall.
