Old 10-21-2013, 11:44 AM   #1
Best way to level 3170DS sunseeker
Hi Folks, new owner of a 2013 Sunseeker, does not have auto leveling system. What is the best way to level unit if not using auto level? Type and location to place the jacks. Thanks
scoto is offline   Reply With Quote
Old 10-21-2013, 12:10 PM   #2
Sunnyfun's Avatar
We use Lynx Levelers under our tires on our 3050s They came with a nice zip case. I just kept them in the basement storage.
Sunnyfun is offline   Reply With Quote
Old 10-21-2013, 12:39 PM   #3
you will have to level by driving up on lynx levelers or boards first then stabilize from the frame to the ground. your standard hand crank stabilizer jack is not designed to level the only thing you could level with would be hydraulic bottle jacks and that would be a real pain.
lbrunning is offline   Reply With Quote
Old 10-21-2013, 12:52 PM   #4
once on lynx levelors best way to secure
Thanks for the reply, once on the lynx levelors what is the best way to secure the unit. Just leave on levelors, or use jacks? cribbing? which part of the underside to I place it on? Thanks
Old 10-21-2013, 01:01 PM   #5
always support from frame of truck chaises. looking at my 3170 if i did not have jacks i would mount two stabilizers at the rear of the frame.
Old 10-21-2013, 01:11 PM   #6
type of jacks or stabilizers
Not to be a pain, but what type of jacks and stabilizers would you use.
thanks
Old 10-21-2013, 01:13 PM   #7
Graduate Member
RoadTrip's Avatar
just go to camping world dot com and search - they have lots of types. We (also in a class c) use scissor jacks for stabilizing. They are affixed to the rear frame and our particular model also has one in the front.
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 10-21-2013, 01:28 PM   #8
leveling RV
The one in the front is that a permanant unit from factory or is it a unit that is placed and if so where do you place it?
Old 10-22-2013, 01:01 PM   #9
Graduate Member
RoadTrip's Avatar
It's factory, and bclemens mentioned that it was only done for a few years and only to the 2860 (if I recall correctly)
And it's smack in the middle, right behind the license plate. It's bolted onto the frame, so I would assume you could do it aftermarket as well.
2013 - 53 days
2012 - 26 days
3170, sunseeker
