TV mount into aluminum studs
So, I watched the video, and while the video was interesting I don't think I'd take it as gospel for an RV install! It looks to be a video more for office than RV.
More easily patched drywall versus the thin sheet wood used in most RV's? I surely would NOT make several pilot holes and then take a 1/2 inch bit to it!
If you must though, tape a big stopper on the bit at the correct depth so you don't shoot through the wall and outside! That would really wreck a day!
I'd say check first and see if there is a manufacturer recommended spot in the area you want to do the install as I do believe most have a wooden area beefed up for a TV mount built into the wall.
I was told when I was looking at mounting a TV in the bedroom of our 2015 Wildcat Maxx, that didn't come with a labeled mount area, but had the obvious electric and cable hookup for that spot, to use inch and a half MAX depth screws and mount on the seam of the wallboard in that area and nothing too heavy! If really unsure, in my opinion, I would suggest taking it to a dealer and let them mount it. At least then if they mess up they have to fix it!
GOOD LUCK!!!
