Old 03-06-2013, 11:44 PM   #1
BF Goodrich all terrain tires
Thinking about upgrading to a light truck tire on my 1500 crew silverado. Have 18" Bridgestone at. Just wondering how the BF Goodrich at`s ride on the 1/2 tons. Curious about the ride and noise. I assume the ride will be stiffer and more noise, but is it excessive. I will probably stay with the factory 265 size.
2013 Salem 30KQBSS TT
Equalizer 4pt Hitch system-12K
2016 Ram 1500 Crew Cab Sport 5.7 Hemi w/8 Speed
Great Laker is offline   Reply With Quote
Old 03-07-2013, 12:26 AM   #2
moondog2000's Avatar
I have BF Goodrich AT's on my 05 Silverado Z78, They are not very noisy, I only hear a small wine on a certain pavment some times. You have to listen for it. I run my tires at max inflation so they all seemed stiff. The plus side is you can run them at 80 psi. I like them and when they wear out I'll put them on again. Good tire.
moondog2000 is offline   Reply With Quote
Old 03-07-2013, 10:11 AM   #3
Dodge Guy's Avatar
You will like the bfg's. i had them on an 05 Explorer in a "C" rating. I have them now on the X in an "E" rating. No noticeable noise, keep them rotated and they are excellent!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 03-07-2013, 11:03 AM   #4
Rolling buckeye's Avatar
Been using Bfg at's for along time,love them. Oh and by the way they are made in the USA a quality not so easy to come by.
Rolling buckeye is offline   Reply With Quote
Old 03-07-2013, 11:09 AM   #5
daydreaming about camping
jeeplj8's Avatar
I had them on a Dodge 1500 and Chevy Tahoe. Loved them on both. Got pretty good wear out of them, but not as good as a less aggressive tire or the Hankook A/T's I went to now.
The BFG A/T KO was amazing in almost all situations. It made boat ramps easy, tore through amazingly deep snow and was great in actual off road situations. The guy who bought my Tahoe took them off because he said they were too aggressive and replaced with Michelins and promptly got stuck in his own driveway.
FWIW - I have also run General Grabber 2's (which look like a clone of the BFG A/T KO) and actually liked them better. This was on a cheap Montero I had and did not want to pay for the BFG's. I thought General's were every bit as good in every situation but cheaper.
On my current rig I run Hankook Dynapro ATM's and am amazed at these tires.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 03-07-2013, 11:35 AM   #6
Helmsey's Avatar
I ran them on my Tundra in 18" load E and loved them for towing, much better than the stock tires that were on it. As far as noise, I don't know that I ever heard them to be honest with you, never have on any of the last few vehicles I have had them on. I'd say you will be pleased with them.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 03-07-2013, 11:44 AM   #7
rotorhead1250's Avatar
Lots of thumbs up for the BFG AT's. All around great tire for off the road.
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 03-07-2013, 06:33 PM   #8
rowdydog77's Avatar
I have BFG Rugged Trail T/A's on my 2000 Silverado 1/2 ton. I really like them. Don't know what the difference is between these and the all terrain, but I will be putting these back on when they need replacement and also on my 2002 GMC 3/4 ton when it is due for new tires.
2002 GMC Sierra C2500 HD 6.6L Duramax Diesel
2013 Sabre Silhouette 291BHTS
Pat, Michele and 2 old dogs, Shug & Sissy
rowdydog77 is offline   Reply With Quote
Old 03-07-2013, 06:47 PM   #9
I don't.know the tec. Difference but I had a set, and they lasted a realllly long time,have to guess they are a harder compound,and a really good road tire.
Old 03-07-2013, 10:27 PM   #10
Dodge Guy's Avatar
The rugged trails have a bit tamer tread than the A/T`s. the A/T`s are a great off road tire and good on road. the rugged trail is a good on road/ off road tire. if you see alot of off pavement travel then the A/T`s are the way to go. if you just do occasional off highway travel then you will like the rugged trails.
07 Cherokee 32B
