I have found tons of people who have issues with their tank monitors, but usually they are showing more than what they have. I have the opposite issue, my gray water monitor never goes higher than 1/3 even after my wife showers three times and washes dishes 3-4 times.
Recently she was in the shower and it was so full it started to flood the tub. She always checks the monitor before she gets in. I checked the monitor when she yelled and it said 1/3 full. Clearly it was 4/3 full since it was backing up into the tub.
To my knowledge this has never been right, but of course when we notice it we have passed our year on the TT. Any suggestions on what may cause this other than the systems are cheap and flawed? I know very little about how they work to troubleshoot.
__________________ Randy
14 PT Avenger ATI 27BBS
09 Nissan Armada
Central Ohio
Does the gray tank show empty after the tank is emptied? (As in, the 1/3 indicator light goes out.)
There should be 3 sensors on the tank: 1/3, 2/3, and full. Each one completes a circuit and lights the corresponding indicator light (the empty indicator is always hot so always lit).
If your gray tank's 1/3 indicator light goes out after being emptied it sounds like the wiring from the tank to the panel is okay (there is only a single wire from each tank to the panel, plus a common ground).
Normally "something" in the tank is stuck to a sensor, completing the circuit when the water level is not actually that high (e.g., panel shows 2/3 full when the tank is empty). In your case it appears the top two sensors are not working, disconnected, or covered by "something" that is non-conductive. I doubt it is the latter since it appears like the gray tank sensors have never worked.
Can you get to the sensors?
Mike
I'll check this when I head over to the storage lot this weekend. Thanks for the help. I have never checked after empty to see if it still says 1/3 full.
09 Nissan Armada
Central Ohio
Even though your RV is over a year old, your dealer may give you a courtesy check on the sensors. That is if you cannot get to them yourself.
That might be the funniest thing I have ever heard. Had my dealer, Tom Raper, not been bought out by Camping World then there is a chance you may have been correct. Honestly I am not even sure I would want CW touching my TT. It seems like every day someone posts another horror story of CW messing their unit up.
09 Nissan Armada
Central Ohio
If by chance the light is out after you emty then the next outing when you drain dump a bunch of Ice down the black and try also to get some down the gray. Drive home and then flush. I had issues with the black and this cured my problems. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Usually when a sensor or sensors are covered with "something" it is conductive, therefore completes the circuit leading to a reading on the panel that is higher than the actual tank level. In this case it is the opposite. For that to be the case here the top two sensors--out of three--would have to be covered with something that is not conductive. Possible, but in my opinion not likely.
Without getting too boring (I hope) there is a resistor before the 1/3 and 2/3 sensors, and no resistor on the full sensor (the resistors are in a little "puck"). This varies the voltage to the single line run to the panel. The panel has a voltage comparator chip (for each tank, plus battery). This chip reads the voltage coming in and uses that to light up the appropriate indicator lights.
Hopefully the OP can find out more this weekend. As getting to the sensors could be difficult it sure would be easier if a cleaning fixes it.
It might just be easier to forget about the whole thing. Just find another way to accomplish your goal. Maybe a grey dump every other day would work. Just make it a part of your ordinary camping routine.
Ok so I was able to get under the TT today and all of the wires are connected and seem to be in good shape. I also filled it up and drove it around about 30 miles. Seems to always show 1/3 even when tank is 100% empty.
09 Nissan Armada
Central Ohio
You can test the panel by removing the cover and removing the grey wire that comes from the grey tank and swapping it with one of the other tanks' wires. If it still shows 1/3 and on the grey indicator it could be the panel circuit board.
