Old 02-13-2015, 06:15 AM   #11
Witch Doctor's Avatar
Originally Posted by Indymule View Post
So on my new trailer, the outdoor shower is located right next to the black tank flush. We never use the outdoor shower. Would it work to take the shower head off and put a 1/2" NPT to garden hose connector on the hose then using a backflow preventer, use the outside shower to flush supply the water for the flush?
My thoughts are that even if camping without water, we could use whats left in the fresh water tank to flush the black tank. I know the pressure would be less but better than nothing.
Also, would there be any problem or advantage/disadvantage to using hot water for this flush? Again if we are leaving, we could use the already hot water to flush out the black tank.
So let's hear the thoughts on this.
I think you would need to increase the size of the water pump to more gpm, or it wouldn't clean the tank.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 02-13-2015, 07:21 AM   #12
We did this and flush with hot water
Copain is offline   Reply With Quote
Old 02-13-2015, 10:07 AM   #13
zs325RES's Avatar
Great subject.
I like the idea of utilizing the hot water for the BTF. I usually just dump the HWH when breaking camp.
Adding a way to also inject some kind of liquid soap (automatic dish washing?) would be a plus IMO. Something in line.
hmmm...
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 02-13-2015, 10:34 PM   #14
Lon
Lon's Avatar
I wouldn't do it
The more I think about it the less I would be inclined to flush the black water tank with the drinking water plumbing. The back flow preventer will not necessarily prevent contamination with organisms like e coli, strep feacalis, staph aureus, Samonella, vibrio cholerae, ect. These are sneaky little guys and if your timing is not perfect with the valves over time you could colonize your clean plumbing. You might get away with chloroxing your clear water plumbing periodically but why take a chance. For my money I'd try to keep your drinking water plumbing as isolated from your sewage plumbing as much as humanly possible. The Great Wall of China comes to mind. Sorry about all the spelling errors. But as my mother used to always tell us brothers when we were young, "keep it clean guys."
Lon is offline   Reply With Quote
Old 02-13-2015, 10:40 PM   #15
trbomax's Avatar
I never thought about that.........what a great idea! Now I have something else to modify/change before we can use this thing!
trbomax is offline   Reply With Quote
Old 02-14-2015, 10:26 AM   #16
I did this on my last 5r and plan on doing it to my new one too. I just made up a little 2 foot hose with a quick connect on one end and an in line back flow valve where it connects to the black tank flush. I pumped out, closed the drain valve and then ran this for about 5 minutes and pumped out again. There is no way to know how much it actually cleaned but I can tell you, the second pump out was pretty dirty too. P.s. Your black tank flush should already have a one way valve in place to keep black water from backing up in your hose but added a 2nd one just to be safe. I do a lot of boon-docking and get pumped out by a truck and the truck stop I use on the way home has free pump out but no running water so I used this a lot. Instead of just draining the fresh tank, might was well put the water to use.
Maxhise is offline   Reply With Quote
Old 02-14-2015, 07:42 PM   #17
gooiebob's Avatar
That's interesting. I am curious why you capped off the hot water line? and since it is capped off, will the water drain out of that line or will it create a vacuum and hold water creating a problem with winterizing.
The water lines are at a tee where I could just put a cap on it. The lines up to the shower faucet were just like faucet hoses. No problem with winterizing. Just have cold water at the outside shower we don't use anyway.
Bob
2013 Rockwood Ultra Lite 2703ws
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 02-16-2015, 05:46 PM   #18
riznfall's Avatar
Go for it. I used mine on our last camper. Definitely slower. But will work.
Tim
Vengeance touring edition 39R12
2012 Ram 3500 DRW
Tim
2012 Dodge Ram 3500 DRW
riznfall is offline   Reply With Quote
Old 02-16-2015, 06:22 PM   #19
gashog's Avatar
I think using the shower, especially the hot water to flush is a great ideal. I have a extra shower hose that will reach the black water flush. I do have a question, my black water flush says to always flush with drain open. Is this really necessary or is it just to a caution not to overfill? Tanks are vented so pressure shouldn't be a issue. Seem like it would be a fast way to add a little water to black tank.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 02-16-2015, 06:30 PM   #20
gooiebob's Avatar
I always close mine to let the water buildup to flush better. Just don't walk away to do something else and think you'll remember to go back and open it. That could more mess then you want. Close it, let it run, open it, and repeat as necessary. Sounds like a medication procedure.
Bob
black tank, tank, black tank flush, black
