Old 02-12-2015, 03:12 PM   #1
Indymule's Avatar
Black Tank Flush
So on my new trailer, the outdoor shower is located right next to the black tank flush. We never use the outdoor shower. Would it work to take the shower head off and put a 1/2" NPT to garden hose connector on the hose then using a backflow preventer, use the outside shower to flush supply the water for the flush?
My thoughts are that even if camping without water, we could use whats left in the fresh water tank to flush the black tank. I know the pressure would be less but better than nothing.
Also, would there be any problem or advantage/disadvantage to using hot water for this flush? Again if we are leaving, we could use the already hot water to flush out the black tank.
So let's hear the thoughts on this.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
2017 Ford F350 Crewcab Dually Diesel
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 02-12-2015, 03:16 PM   #2
TURBS's Avatar
Interesting concept!
I don't know why it wouldn't work jay.
Hot water may be a plus!
Old 02-12-2015, 04:18 PM   #3
arpipeliner's Avatar
Know guys that have their outside shower and do the hot water. We always stay where full hook ups as we work when in the camper. We open the FW and let it drain but good point on your topic.
I haven't cause I use mine a lot to rinse off the work boots before putting on the boot dryer.
arpipeliner is offline   Reply With Quote
Old 02-12-2015, 04:33 PM   #4
Indymule,we use our (OSS) to supply (Pink Stuff) to the black tank flush for winter,so we are already plumbed for (Garden Hose). Just Mix the (H & C) before you supply to the BTR. Camp On!! Youroo!!
Old 02-12-2015, 06:12 PM   #5
gooiebob's Avatar
I removed the shower head and changed it over to use on the black tank flush when we got ours new. I also disconnected the hot water line and capped it under the cabinet. Never used it as its on the neighbors side anyway.
Bob
2013 Rockwood Ultra Lite 2703ws
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 02-12-2015, 06:32 PM   #6
You could do it. I asked my dealer last year and they said that by law they could not connect fresh water to any kind of black water. If your back flow valve failed it might get ugly.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 02-12-2015, 09:58 PM   #7
Indymule's Avatar
Bob
That's interesting. I am curious why you capped off the hot water line? and since it is capped off, will the water drain out of that line or will it create a vacuum and hold water creating a problem with winterizing.
Ham Callsign K9NDY
Old 02-12-2015, 10:50 PM   #8
Lon
Lon's Avatar
I don't know why they don't connect a one way valve drain from the grey tank into the black water tank. Then ud have soapy water flushing ur black tank and on pulling up stakes u could turn the shower on to drain what's left thru both tanks. But good thought TANKS a lot!
Lon is offline   Reply With Quote
Old 02-12-2015, 11:03 PM   #9
Mojojojo's Avatar
Stink tank ,think tank here. I was planning on putting a brass Y valve with two separate shut offs on the inbound line with a quick connect to the supply hose and just leave the other two hooked together ,so I can turn off the trailer fresh side and open the flush side when needed. Anyone do that yet?
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
Old 02-13-2015, 05:35 AM   #10
realebill's Avatar
Mojojojo..I have had my flush hooked up like that for a few years now.never had any problems.brass "Y" with shutoffs at the fw inlet .short hose to the bt flush.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
black tank, tank, black tank flush, black
