Old 06-18-2016, 05:43 PM   #11
Originally Posted by Charles Firth View Post
Interesting, I always flush the black tank but I have the valve open while doing so. Am I doing it wrong ?
You are doing it correctly. My Wildcat has a warning sticker that states the black tank valve must be open when using the black tank flush hose hookup.
Skyliner is offline   Reply With Quote
Old 06-18-2016, 06:50 PM   #12
No you're doing it correctly. Mine also has the warning stickers. But as stated above, it is an easy way to fill the tank from the outside.
I am not advocating doing it with the valve closed. I just don't understand why it can't be done with out building up enough pressure to possibly pop steel bands or bolts as stated by OP. My tiny brain tells me if the water was left on, the tank would eventually fill to the point of over flowing through the roof vent. Thereby creating the unsafe and dangerous condition stated on the warning label. But that is not the case. The water being added is definitely compressing air like an aersol can. The only thing I can think of is the vent pipe has some sort of check valve which prevents the air from escaping, but that doesn't make sense to me either.
tkarper14 is offline   Reply With Quote
Old 06-18-2016, 11:22 PM   #13
Edit above: you are not doing it incorrectly is what I meant to say. Sorry for any confusion.
Old 06-19-2016, 07:42 AM   #14
JustB_Rad's Avatar
Weird, mine has a warning to not turn on the black flush unless the valve is OPEN. I'm sure they have that warning for a good reason!
JustB_Rad is offline   Reply With Quote
Old 06-19-2016, 07:50 AM   #15
B and B's Avatar
I can use my black tank flusher at the dump station now. I find 30 seconds to 1 minute at the most keeps it clean as a Kitchen!! No need to waste so much water, filling a tank 3 times is enough water for 200 plus people to DRINK and prepare food in a day!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-19-2016, 07:55 AM   #16
Canadian Member
itat's Avatar
I also use the flush with the valve closed to fill the black tank. It does a better job than just the flusher alone. It's really a 2 person job and you can't be distracted while doing it. I stand outside at the valve while my DS stands at the panel constantly checking the levels. As soon as the full light starts flashing I open the valve. I do that twice if I have a full hookup site or if no one's behind me at a pump out station, once if there's a lineup. I also use it to leave some water in the black tank after completing the dumping process.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 06-19-2016, 07:56 AM   #17
DouglasReid's Avatar
we are all human
For the VERY reason described in this thread, human frailty!
DouglasReid is offline   Reply With Quote
Old 06-19-2016, 07:56 AM   #18
Traveling Two
jerryliving's Avatar
I remember reading somewhere on the forum about a mixture to clean your tank when you are home. Does anyone have that?
jerryliving is offline   Reply With Quote
Old 06-19-2016, 07:57 AM   #19
It normally takes me at least filling black water tank at least twice. My tank stays clean, I don't use any chemical treatment in black tank. Anyway it works for me
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 06-19-2016, 07:59 AM   #20
AKA: 'tiredTeacher
awellis3's Avatar
Exactly! I flush with the valve closed. I pull the handle every 3-4 minutes until the "lumps" stop appearing in my see-through elbow.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
accident, black, black tank, black tank flush, tank
