Old 10-13-2016, 09:58 AM   #31
The built in black tank rinse on my TT doesn't work well at all. If i look down into the toilet I can still see "stuff" even after the rinse water runs clear.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 10-13-2016, 10:02 AM   #32
BandJCarm's Avatar
Are you filling up the blank tank via the flush, completely, before dumping?
Have you tried adding Calgon or water softener?
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 10-13-2016, 10:08 AM   #33
What I see down there are loose material, nothing stuck even when the rinse is running.
I would assume that the rinse would "rinse out the tank" I guessed I assumed wrong.
Old 10-13-2016, 10:14 AM   #34
NMWildcat's Avatar
You would think, right? I think it depends on how the guy at the factory was feeling the day he selected the position of the nozzle. I had one rig that rinsed very well with only the flush. My latest one does not. So when it's time for a thorough clean I repeatedly fill the black and flush.
Scott and Liz - Southern NM
Old 10-13-2016, 10:17 AM   #35
BandJCarm's Avatar
I can't get rid of loose material by leaving valve open and running water. There's always a lot of residual solid matter when doing it that way. The only success I've had is filling the blank tank repeatedly with water, and then flushing out a full tank.
Maybe tanks are different, or maybe I'm doing it wrong. I have a major black tank issue, maybe that's at fault. I don't know.
FROG AR-0019-242
Old 10-13-2016, 10:22 AM   #36
This goes back to the OP about people spending too much time at a dumping station. I've done the fill, dump, fill, dump method before but it's time consuming. It's not something you want to do while others are waiting.
Old 10-13-2016, 11:48 AM   #37
BeeGee's Avatar
Even if it only takes 15 min to flush, if you're 6th in line you will be there for 1 1/2 hours. It's common when you have lots of campers and not many dumps. It's true everywhere. There are too many people on earth!
2012 Ford Lariat F-350 Super Duty
2014 Forest River Cherokee Wolf Pack 27 TH
BeeGee is offline   Reply With Quote
Old 10-13-2016, 12:12 PM   #38
I was at a campground once where the dump station was on the exit road. People behind me were waiting just to leave
Old 10-13-2016, 12:36 PM   #39
Traveling_Boilers's Avatar
I'm guessing there are lots of things that "other" campers do that tick you off. Get over it.
FIDO - Forget it, drive on.
Traveling Boilers
2016 Rockwood Mini Lite 2109s
2017 nights camped = 9
2016 nights camped = 12 (first year)
www.travelingboilers.com
Traveling_Boilers is offline   Reply With Quote
Old 10-13-2016, 12:46 PM   #40
Originally Posted by born2ride41 View Post
Good point but I don't think there is a trap in the drain pipe to the black tank is there?? I am pretty sure I can see directly into the tank when I flush the toilet!? I know there is traps connected to the sinks etc but never really thought about the toilet since I thought I could see directly into the tank!
I'm talking about the drain pipe between the black tank and the release valve where you connect your sewer hose. I guess it depends on where that valve is as another has posted...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
black, black tank, black tank flush, tank
