Old 07-19-2016, 08:50 AM   #1
mnwild58's Avatar
Black water holding tank sensors and saniflush
Well sensors are red saying I am full I just dumped black water tank! Ok, went to rv dealership and said use Command to clean up tank, ahhh didnt work!!! Also noticed my saniflush is not working either! Any suggestions?
mnwild58 is offline   Reply With Quote
Old 07-19-2016, 09:01 AM   #2
clr
Get the flush system working and forget about reading the indicators for tank status. The tank status indicators all most never work correctly and you can spend a fortune trying to get them to work. If you NEED the indicators to work for your piece of mine, replace them with HORST miracle probes and be done with it.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 07-19-2016, 09:03 AM   #3
mnwild58's Avatar
Do these probes install into same holes of tank
Old 07-19-2016, 09:27 AM   #4
Tank sensors should only be used as a guideline. If I want to verify if my black tank is full, I just shine a flashlight down the toilet.
Sent from my SM-G900V using Tapatalk
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 07-19-2016, 09:38 AM   #5
I'm didnt work from the factory at dealership getting looked at
railroaderone is offline   Reply With Quote
Old 07-19-2016, 09:45 AM   #6
mnwild58's Avatar
Just looked at horst sensors on youtube; way better setup then o.e.k sensors
Old 07-19-2016, 01:09 PM   #7
jtesta1's Avatar
Tank sensor
My black tank works in reverse all light's empty no lights full
jtesta1 is offline   Reply With Quote
Old 07-19-2016, 01:16 PM   #8
Black Tank Cleaning
OK I know I'm old fashion but the cleaning wand that you put down the toilet will clean the system much better than the "flush port" on most newer trailers. It's not as convenient as the built in system but if you care about using the sensors it will let you clean the walls well.
DocRob is offline   Reply With Quote
Old 07-19-2016, 01:36 PM   #9
Completely agree with this. Anytime I dump and the lights aren't correct. I use the cleaning wand. My camper is a 2013 and the lights are still working correctly.
dmeyer is offline   Reply With Quote
Old 07-19-2016, 02:01 PM   #10
mnwild58's Avatar
I have seen the wand, i may have to get the flexible one because i have a 90 at the bottom of my toilet! Can clearly see it
black, black water, tank, water
