Old 08-20-2016, 12:43 PM   #1
jonrjen's Avatar
Black water tank rinse valve not working
We have a Wildcat 5th wheel that has two black water tanks as well as two grey water tanks.
There is a Black Water rinse valve located in the outside compartment for hooking a hose up and rinse the black water tank or tanks.
Problem is if I hook a hose up to the inlet and turn the water on the hose builds up pressure but no water flows past the inlet into the tank or tanks.
If you noticed I keep saying tank or tanks. Since I have two black water tanks would the rinse if working spray both black water tanks at the same time or is there a diverter valve somewhere that would need to be switched?
Fifth Wheel is a 2013 Wildcat 353LS for reference purposes.
Thanks for any assistance,
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 08-20-2016, 07:45 PM   #2
Did you try removing the filter screen on the inlet to check if it's clogged?
Sent from my iPad using Tapatalk
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
black, black water, tank, water, water tank
