05-16-2017, 11:18 PM
#21
I plug an extension cord into the 20 amp outlet and make the wife dry her hair at the picnic table. 😀
Sent from my XT1080 using Forest River Forums mobile app
"I used to be disgusted, now I try to be amused."
Elvis Costello
2015 Sunseeker 3010ds
05-16-2017, 11:20 PM
#22
My wife uses one all the time. Tripped a breaker once when a.c. was on....... Learned real quick to make sure no access or coffee pot of n 30 amp. 50 is good..... That's the only thing that can happen is tripping a breaker..... Just make sure no other hogs are in the pen when on 30amps.
05-16-2017, 11:33 PM
#23
My DW uses a "travel" blow dryer. Uses less watts. Does take longer.
2014 Sabre 33CKTS
2012 F250
05-17-2017, 07:43 AM
#24
Towel.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
05-17-2017, 09:27 AM
#25
50 amp rig & 50 amp pedestal. [emoji16]
05-17-2017, 11:45 AM
#26
Originally Posted by Mr Havercamp
My wife is notorious for kicking the breaker when camping in the fall. We usually have a 1500 watt electric heater going, and she has never been able to comprehend when she puts the toast in, right before the smoke alarm sounds(another lesson that can not be absorbed), the little brown box under the fridge will click and everything turns off. I have come to the conclusion I will reset a breaker every morning at least once while camping in the fall or early spring (and remove and reinstall a 9v battery), for the rest of my life. At least she does not use a hair dryer often when camping LOL.
Now thats Funny.....
Dave...Northern Nevada
2018 Rockwood 8299bs
2007 GMC 2500HD Diesel SLT short bed w/gravity flow75 gallon Fuel Tank.. Cat delete
Firestone Airbag Ride Rite system
05-17-2017, 12:19 PM
#27
Not so many years ago, I usually camped with my wife and 3 daughters and 2 of their friends. Having 4 teenage girls along, they learned real quick to head to the bath house to do their hair! Momma and the little one stayed put and it was my job to keep the air on and the electric flowing! I just had to manage which AC to keep running depending on which bath they were in.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
05-20-2017, 08:13 AM
#28
Originally Posted by mlatter
A blow dryer will take half of your 30 amp service, so just be sure that other big appliances aren't operating at the same time - microwave, electric water heater, air conditioning. You shouldn't blow any fuses or breakers if you're careful.
X2
When I had the 2015 Rockwood Roo 30AMP, wife would blow it with hair dryer when air was on. Had to turn AC off let her use it then turn AC on.
Some hair dryers use up to 20 AMPS, read the info on yours, also remember you don't have a full 30 AMPS to you, here is a short estimate of AC AMPS.
120 Volt AC Amp Ratings
Appliance or Electronic Equipment
Estimated Amps
Air Conditioner (X number of A/C)
12-16 Amps
Blender
5-6 Amps
Coffee Maker
5-8 Amps
Compact Disc Player
1 Amp
Computer (Laptop)
2-3 Amps
Converter
1-8 Amps
Crock Pot
1-2 Amps
Curling Iron
<1 Amp
Drill
2-6 Amps
Electric Blanket
0.5-1.5 Amps
Electric Fan
1 Amp
Electric Water Heater
9-13 Amps
Electric Skillet
6-12 Amps
Hair Dryer
5-12 Amps
Iron
5-10 Amps
Light (60 watt % 120V)
<1 Amp
Microwave
8-13 Amps
Microwave (Convection Oven)
13 Amps
Refrigerator in AC mode
5-8 Amps
Space Heater
8-13 Amps
Television
1.5-4 Amps
Toaster
7-10 Amps
Vacuum (handheld)
2-6 Amps
VCR
1-2 Amps
Washer/Dryer
14-16Amps
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
05-20-2017, 11:38 AM
#29
check your amps
Remember, your rig is supplied by single phase voltage. The volts to your rig averages 117. All your circuits come together on the bus at the 50 amp point. Each circuit is protected by its own breaker/fuse.....the problem you will have is tripping the main (50 amp) A hair dryer at 1500 watts draws 13 amps. Your ac units will draw right at 15 - 20 amps. That's why you trip the breaker when both are on.
To calculate your appliance amps , divide the wattage by 117 and your answer is the amps. Remember everything that is on, adds together. So your 1500 watt dryer is 13, your ac is 20. Total is 33 amps. 30 amp plug wont hold it. You may even have your hot water heater on, if so change it to gas. Same with fridge. You could still have the same problem on a 50 amp IF ALL these hogs are on and operating.
05-20-2017, 11:42 AM
#30
Ok which one of us guys are brave enough to say "No blow drier", not me. Lol
2014 Sabre 33CKTS
2012 F250
05-20-2017, 11:57 AM
#31
The whole reason for going Rving is to enjoy time with each other. She can bring anything she likes. We will make it work
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
05-20-2017, 12:06 PM
#32
My Goodness! We lost Marinewife a long time ago. We are waaay over thinking her question and being no help to her. If we want to demonstrate our electrical/math skills let's start a thread for that. For Marinewife just give it a try. If a circuit trips then shut down some of the things using electricity, flip the breaker back on and try again. It will soon become clear.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
05-26-2017, 04:32 PM
#33
I read them all and it was interesting. An electrician I am not!
I will be using my blow dryer and loving it! Thank you all.
Melissa
Wife to a Retired Marine
Mom to Six
2018 Wildwood X-Lite T282QBXL
2005 Ford E-350 XLT
2017 Ford Expedition EL XLT
05-26-2017, 07:06 PM
#34
I don't think we lost anyone.....it is just basic math.... And we all have been or will be in the same situation and needed to know why the breakers trip and how to avoid it......it really is very simple....just flipping a breaker back on is not really the answer, of you don't know why it tripped on the first place....it will just keep tripping and the user more frustrated.....
