Old 07-06-2013, 10:35 AM   #1
2011 Forest River Stealth
rwtdct's Avatar
Angry Blow out and the fix
I recently had a blow out (peeled a cap) on my toy hauler. It ripped my fuel station door off and bent up my skirting. I came up with a temp. fix.
The fix.
2011 Stealth CSFCK3214
2003 Ford F250 Crew Cab 4X4 7.3
2011 Polaris RZR 4
rwtdct is offline   Reply With Quote
Old 07-06-2013, 12:02 PM   #2
Ahhh, when isn't checkerplate useful? Nice save.
Cheese
Mistacheese is offline   Reply With Quote
Old 07-08-2013, 08:53 PM   #3
I am a sheet metal worker by trade and we are looking at up grading 5ER's we have had a couple blowout on our present camper. I have been thinking that the first thing I will do will pull the tires off and build a metal fender well out of either stainless steel or aluminum so when I do have another blowout it will not tear up anything
Any thoughts from anyone else?
sbreen is offline   Reply With Quote
Old 07-08-2013, 09:19 PM   #4
When I had the blowout, the major damage was to the alum curved sheet, not to the fender well itself. The tread flies loose but still connected to the carcass and beats the devil out of the rolled alum trim.
Name:	Tire Damage 1.jpg
ID:	34851   Click image for larger version
Name:	Tire Damage 4.jpg
Old 07-08-2013, 09:41 PM   #5
I don't know why manufactures don't beef up these areas. Hope someone from FR reads this and decides to change this area of the campers I think they would get a lot of good reviews from it
Old 07-08-2013, 09:57 PM   #6
Do I understand you're using "recapped" tires? That would scare the heck out of me!
Old 07-08-2013, 10:03 PM   #7
It will do the same to a car or a truck. Couldn't beef it up enough to prevent damage and if they did, it would have to be 1/4" steel plate. Easiest thing to do is get GOOD tires and a TPMS.
Old 07-13-2013, 07:47 AM   #8
rwtdct's Avatar
These are the original tires that came with the T/H, 2 1/2 years old. (Not Recaps). My opinion, most trailer manufactures install cheap tires.
My first 5ther I had less that two years. I had a blow out, with-in two months later all my other original tires all were egg shaped (Busted Belts). Tire manufacture...Carlisle.
This had happened in 2005. They might make a better tire now. But I stay away.
2011 Polaris RZR 4
Old 07-13-2013, 07:55 AM   #9
rwtdct's Avatar
What brand tire was it????
2011 Polaris RZR 4
Old 07-13-2013, 08:49 AM   #10
I think Ultra LRT if I read the sidewall correctly.
Name:	Tire Damage 2.jpg
Old 07-13-2013, 11:34 AM   #11
sail2liv's Avatar
as usual with tire posts no info on weight, speeds, temp, psi, how tires were maintained.....so far no blowouts here, but try and keep weight at 80% of max and speed...never over 60 mph///mostly 56-58 mph range....and always use TPMS and keep pressure at max all the time including when parked....plus the tires roll regular...
longest layup a couple of months when wintering in Fla....even though no on road keep pressure at max ... good luck, I can only imagine that a blow is no fun...
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 07-13-2013, 07:41 PM   #12
Dodge Guy's Avatar
You think that`s bad wait till you see one that breaks off the plumbing connections. not mine but a neighbor in a campground.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 07-13-2013, 07:51 PM   #13
Guest
On my old trailer the Duras it came with were rotting through the belt at the two year mark. Replaced them with Goodyear Marathons and got a set of tire covers. Whenever it's parked in storage, the covers on the tires. Doing the same with the tires on the new camper. However, I'm sure I'll discover cracks again within a few years.
John4th is offline   Reply With Quote
Old 07-13-2013, 07:54 PM   #14
Trailer was 4 months old, factory tires at 53/55# due to having traveled approx. 200 miles, traveling 55mph, ambient temperature 90°, approx. 20 miles north of Springfield, MO traveling south on US 65. No tpms. No water in any tank. Tire Pressure was verified at gas stop approx. 15 miles previous. Tires were also balanced.
Old 07-14-2013, 10:25 AM   #15
rwtdct's Avatar
Tires were a little less than 2 1/2 yrs old, I was well under weight, I was between 60 and 65 mph, temp approx 90, I always keep my tires at max or with-in a couple pounds under max (all even). My 5ther is parked in a 34' X 36' enclosed building (no sun exposure).
I am not one to just hook up and go. I keep my trailer very well maintained.
My previous 5ther I had same problem with the original tires with-in two years. I had LT (light truck) tires installed on it and lasted 8 yrs.
2011 Polaris RZR 4
