Old 06-29-2015, 01:14 PM   #11
Blowouts
Like you I have towed trailers for many miles and over many years. I have only had one blowout and that was about six years ago. It took off my steps, my awning support, the lower panel on my trailer skin and bent some of the frame structure. I consistently checked my air pressure. The tires were from the factory and had less than 2000 miles on them. At that time I did not have a TPM. I do now. The repair cost was over $2200.
dwebster is offline   Reply With Quote
Old 06-29-2015, 01:16 PM   #12
camaraderie's Avatar
OK...here's a question for class A's loaded to a little less than rated capacity.
My tires say 105 psi max on the sidewall...but the sticker inside the cap says inflate all to 82lbs which is what I have done for the last year. Drives well at that inflation and inspection reveals no undo wear patterns at 5k miles.
I guess I'm concerned from this thread that closer to max inflation is where I need to be. But why would they have me 20lbs. less on the cab sticker for the tires that are on the rig?? Or is the discussion above strictly related to trailer tires?
EDIT...BTW...they are Goodyear 245/70R 19.5" tires.
178" wheelbase/29ft coach/18k GVWR Same size as all non XL G'Town tires but I'm thinking our lower weight chassis (requires less inflation than a 351 or such)?
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 06-29-2015, 01:23 PM   #13
Ford Idaho's Avatar
Who knows more about the tires, the people who built your unit, or the people who built the tire?
Old 06-29-2015, 01:32 PM   #14
siskom's Avatar
tire blowout
A friend and I were traveling to the Florida Keys in April on the way down its only 300 miles he had a blowout on rear drivers side tire. All it did was dent up the J-channel behind the tire. On his next trip couple months later he had another blowout that did substantial damage $6000 worth, needles to say he now has all new tires. But some of the other responders are correct tires should be somewhere between what is stated on the tire (cold pressure) and what the trailer manufacturer states. DO NOT UNDERINFLATE THEM you will certainly regret that.
siskom is offline   Reply With Quote
Old 06-29-2015, 01:58 PM   #15
I hear ya Ford...but here is what Goodyear SAYS on their site:
Maintain Inflation Pressure At The Recommended Level
This level is recommended by the vehicle manufacturer and is shown on the vehicle placard or in your vehicle's owner's manual.
Maintaining proper inflation pressure is the single most important thing you can do to promote tire durability and prolong tread life.
Underinflation is the leading cause of tire failure and may result in severe cracking, component separation, or "blowout." It reduces tire load capacity, allows excessive sidewall flexing, and increases rolling resistance, resulting in heat and mechanical damage. Over inflation increases stiffness, which may deteriorate ride, and generate unwanted vibration. Over inflation also increases the chances of impact damage.
So it seems to me that 82 lbs is correct and if I need to go higher for handling, or loads or cold temps...I should not exceed the 105 on the side of the tires.
It's just that a 23lb spread seems like a LOT to me.
________
Cam
Old 06-29-2015, 01:59 PM   #16
A number of years ago I had a single axle travel trailer. It still scares me today to think what might have happened had one of the tires blown! I have had two blow outs on a fifth wheel and never knew they blew. It was only when a passing motorist signaled me that I found out. I have had one blow out on a toyhauler it was the same thing, couldn't tell it. When one blows the whole load is now on the other tire and it is just a matter of time before something bad happens. This is why today I have a TPMS. While it may not stop a tire from blowing, I will know it and can put the spare on before something catestrophic happens.
comfun1 is offline   Reply With Quote
Old 06-29-2015, 02:04 PM   #17
I've only towed pop-ups (single axle) for the last 25 yrs, with many trips across the country. The only blow out was while I was going tooo fast in i-90 in SD. Heard it go, but was not sure it was me until I stopped to check.
The only time I really worry about it is when I'm reading through this forum.
Underthedog is offline   Reply With Quote
Old 06-29-2015, 02:10 PM   #18
Ford Idaho's Avatar
I can understand that however IF you inflate to the sidewall spec's you are NOT over inflated.
By all means run the PSI where you feel good at.
Old 06-29-2015, 02:27 PM   #19
I have a vibe with the same tires, but mine came inflated with nitrogen instead of regular air. Don't know if this will help, but it seems safer.
craignhouston is offline   Reply With Quote
Old 06-29-2015, 04:40 PM   #20
2012 Micro Lite 21 FBRS
Guapotims's Avatar
If your rig has had the wrong size tires put on it, there will be a variance in what your sticker says and what your tire says. This would make a good reason for staying with the correct size tires on your RV. Go by tire sidewall. Check your sticker to see if your tires size match it. I believe Radial Tires will tear up your underside more than a bias ply due to how the Radial is constructed. I wonder if a study has been done on this. Anyway, irregardless of milage on tires, they should be replaced every 3 to 5 years due to breakdown of rubber.
Guapotims is offline   Reply With Quote
